Required Thread Info:
1. What YOUR PC will be used for? Gaming (RPG's and FPS's)
2. My budget: $300, maybe $350.
3. What country YOU will be buying YOUR parts from. USA.
4. IF you're buying parts OUTSIDE the US. No, most likely newegg.
5. IF YOU have a brand preference. AMD.
6. If YOU intend on using any of YOUR current parts. All except ones I want replaced.
7. IF YOU plan on overclocking. Maybe.
8. What resolution, not monitor size, will you be using? 1920x1080
9. WHEN do you plan to build it? When the parts are in.
10. Do you need to purchase any software? No.
Current Build
Motherboard: Gigabyte AMD 760G
CPU: AMD FX-4100 Zambezi 3.6GHz
GPU: AMD Radeon HD 7750 1GB
RAM: 8GB DDR3 1333
Storage: 500GB WD 7200RPM 16MB Cache
PowerSupply: Apex SolyTech SL-400TF 400W
Question
I'm needing some help on what to upgrade first... I'm thinking of replacing the motherboard with a 990FX motherboard from either ASUS, Gigabyte or ASRock first. Then the second part I want to upgrade, I'm still unsure about.. Should I buy better ram, gpu, or supply? What do you guys think I should upgrade?
Current Build
RAM: 8GB DDR3 1333
Question
