Upgrading a Computer, want to check parts compatibility
nick1985
27,158
Originally posted by: phil4856
any good idea for an easy to overclock athlon that will work with that motherboard, around $130 or less?
i already suggested one pal ;)
nick1985
27,158
Alright.. Do i really need a heatsink?
::stays calm and holds in rage to blow up on the new guy::
yes, you need a heatsink unless you want your computer to fry. ;) the heatsink i pointed out is quite good although its cheap. i overclocked my brothers athlon 1800 by almost 700 Mhz with it. i highly recommend it.
EDIT: yeah, look at mechbons installation guide for more information on how to assemble this.
phil4856
14
My apologise.. thanks to you all so much for the help.. Im listening to eveything you said (except the case, cause i want a window (haha sorry))
but yea, thanks a lot.. im sure ill be back when i need help installing it ;)
nick1985
27,158
well keep in mind the case i pointed out has an awesome power supply, and free shipping. shipping alone is usually 15-20 bucks. and if you buy a case with a window for like 50 bucks, you gotta pay shipping so right there you are at the price of the antec, but you get a piece of crap power supply instead of a nice one. and i always say, the power supply is the most important part of a computer....
Sonic587
1,146
Phil, this is the best bang for the buck out there right now. It's the same one nick said to get except it's the 35watter. That means it runs cooler at the same speed because it needs less voltage. These overclock on average to what the mobile 2600 does(the second link you posted)
nick1985
27,158
what do you think about this processor instead? (is it even compatible with the motherboard you suggested?)
http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-342&depa=1
or maybe this:
http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-436&depa=0
(better price on the second one)
id stick to the athlon mobile 2400 since you are on a budget. its the best deal IMO. i got one to 2.45Ghz with the motherboard i suggested to you.
phil4856
14
Ok, thanks, and since the speakers you reccomended are 6.1, am I going to need a soundcard??
nick1985
27,158
well you can scale those speakers back to a quality 2.1 if you want. i only added a 6.1 sound in because thats what you had originally so i assumed you wanted a lot of speakers.
