Upgrade from integrated to a card <$100
  • Mfr Part Number: AL-A300ATX/SL-8320BTX
  • Features:
    • Proprietary IC & unique design
    • Embeded thermal sensor
    • Low noise variable fan
    • Various safety protection: OCP, OVP, SCP, UVP, OPP
  • Input Range: 90~132V or 180~264V AC
  • Input Frequency: 47 ~ 63 Hz
  • Input Current: 8A/4A @ 115/230 Vac
  • Efficiency: 65% at full load, nominal line
  • Output: 300 W
  • Cooling: 1x 80mm Ball Bearing fan
  • Connector: 1x 20+4pin Main Power; 4x IDE; 1x SATA; 1x FDD
I know the unit isn't much, but unless you see something here that should steer me off, I think Ill go with the 4670.
Why? Any day of the week? Weak. The card loses to everything except a 9500gt, ties a 4650. A $60 card that's worth $30-40?
I was giving examples of cards that are equal to the aforementioned 9500GT for less or superior to the 9500GT at the same price point. And within that context, which is plainly obvious given that I was continually referencing the 9500GT, what is your problem exactly?
Had I intended to answer the more absolute question of which cards are superior, I would have done so. I get to choose the context of my replies, not you, so why don't you go fuck yourself?
  • Features:
  • Output: 300 W
I would seriously look into getting a decent PSU. If nothing else, you'll save a good chunk of money on your power bill. Depending on how often that PC is used, that $35 Corsair PSU will pay for itself in less than a year...
K? We all get to quantify the recommendations given by everyone. You made a recommendation off another sucky recommendation and then stood by it any day of the week. My problem is, it's generally bad advice. If you take exception to that, fine. It was the first time I've seen a gt 220 put forth. I'm sorry your ego is so tied to that card.
On the PSU Google says the
15A(180w) on the 12v so you're looking at around 120-140w (75%) load on the 12 volt.
Doing the 12v load calc
25w e5200
45w 4670
35w g31 chipset
25w misc
130w
I think the 4670 fits your system fine.
25w e5200
45w 4670
35w g31 chipset
25w misc
130w
those are typical for the majority of gaming but he could easily go over that at times. also I can almost guarantee you that psu cant actually provide 15amps on the 12v in real world conditions. still shouldnt be a problem but anything more than a 4670 would certainly be risky for long term use.
That was 75&#37; of 15a so 11A, and to generally get to that wattage the OP would have to run prime and furmark. I was generally over estimating.
Edit: I misread your last sentence. So, I'm fully in agreement.
xchecker, if you do buy the HD4670. Your son will enjoy the new graphics card for sure. I use the HD4670 my self and I enjoy it.
Thanks everyone for all the useful comments. I ordered up one of the 4670s recommended here and we'll be installing it together on Xmas day no doubt.
You have a nice board - good info and good people.
