- Oct 19, 2004
- 3,623
- 366
- 126
Originally posted by: kmmatney
I saw some huge gains going from a X850XT to my 2900Pro (equivalent to a 3870) - I think it will be a decent upgrade for you. I would have recommended a 9800GTm but the card you ordered is great for the price.
Not sure I understand you last question, but I wouldn't remove the heat spreader. WHen did you get an X2? Is it a Toledo? You probably need to update the BIOS to teh latest revision, so do that beforehand with your Venice.
I was referring to the heat spreader that comes with the cpu itself. If I don't take it off the X2, I will have to buy a new cooler since I had to modify the XP-90. Any opinions?
