Originally posted by: TechnoKid
So you are leaking clutch fluid. Hmm....If its just a loose bleeder screw ten you may be good. If its a leaking slave cylinder or a leaking master cylinder, then you are screwed untill you replace those. I suppose if it is a slow leak you can put some brake fluid in the master cylinder resovoir till you get home.
When you do get home, make sure you put something under that car so the fluid doens't get everywhere.
Could you give me a ballpark on what it will cost me if I just take it right to the shop to get fixed? I know you have no idea what labor is, but any rough estimate would be helpful.
A new clutch master cylinder is anywhere from $67 to $114 for the part, and ~$20 for a repair kit. A new slave cylinder is about $55, repair kit is ~$10. These are all wholesale prices. And as for labor, I'd say only about an hour at most, so figure about $65-$90 for labor. Add a coule bucks for the hydraulic fluid. At most you are looking at about $250 for a new master and slave cylinder including labor.
EDIT: You said the fluid is leaking inside the car by the clutch pedal or its leaking outside the car onto to floor(ground)???? if it is leaking inside then its most likely the clutch master cylinder that needs to be replaced. If its leaking outside the car, it could be either, but most likely the slave cylinder.
