UPDATED: Running Shoes recommendation (Nike Air Pegasus '02)
Biggs
3,010
I'm 5'11" and 145-150 lbs and seriously looking into the New Balance 1221,
New Balance 1221
I've done my homework by reading various online articles and here's what I've come up so far.
1) My actual foot is 9.5"(US size).
2) Using the "water test", I've determined that my arch is normal.
3) I'm not sure what my pronation factor is but I did notice that my old casual leather shoes have even wear on the forefoot and heel areas. I guess this makes me a neutral but I'm not 100% sure.
According to Road Runner Sports's description of this shoe(i.e. NB 1221), this is for people with medium- to large-frame and medium to low arches. Furthermore, in order to get this recommendation from the Shoe Dog Finder,
Shoe Dog Finder
one has to input "181 lbs and more" in the weight input box.
Would using this shoe then have any negative effects on me if I use it?
P.S.
Finding a specialty running store, unfortunately, is not an option for me.
Many thanks.
Analog
12,755
I can tell you from personal experience (I'm 145#, 5'9") - that if they say its for heavy or large framed people, stay away from them. A few years ago, I bought the Brooks Beast, which was their "top of the line". Later, after some knee trouble, I found out that these shoes are for "large framed" people. That really means that the cushioning is much harder, so as to give it decent life under the extra stress of the heavy person. For a lighter weight runner, that means you're pounding your joints more. Not worth it IMO.
After doing much research, I have found that the Nike Pegasus is about the best cushioned shoe around, great for the lighter weight runner. I have gone through 4 pair now over the years, I usually replace shoes yearly. Sounds like you're doing your homework. Its not worth getting injured, believe me.
Anyway, keep that in mind and I hope that helps you. Cheers. :):)
Biggs
3,010
You're right on the money on this one. I indeed had the philosophy that since this is the New Balance "top of the line", it must be the "better" choice. Thanks for great tip.
Btw, isn't the Nike Pegasus a "walking" shoe? Would this be then alright to use for running since manufacturers tend to use their best technology on their running shoes?
Analog
12,755
yes, you are correct that the link you provided is for the walking version, but Nike makes nine different 'Pegasus' models. Goto here and search for pegasus. Then click on the men's air pegasus:
Men's Nike® Air Pegasus '04
For The High-Mileage Runner Seeking A True Cushioned Trainer. Best For Small- To Medium-Framed Runners With Medium To High Arches.
HTH
Dunbar
2,041
I've always found New Balance to be much more comfortable than anything else. The Pegasus feels rock hard in comparison. Go to Sportmart and try on some shoes to see which one you like.
Amused
57,240
19,135
I just switched to Mizuno. I'm 196 lbs fully hydrated, 192 lbs after a run. Although none of them are "rated" for large frames, the Mizuno fit and rides the best for me when running. It also cured some foot problems I was having.
I got the Mizuno "Wave Mustang" if you care to try it. Great shoe. I went to a local Mom&Pop running store and tried on dozens of shoes. I was expecting to walk away with my old favorite, New Balance, so liking the Mizuno surprised me.
SWScorch
9,520
The 1221 is a stability shoe, meant for people who overpronate slightly. If your shoes have wear down the middle of the forefoot outsole, then you're probably not an overpronator. (Then the wear would be on the inside, towards the big toe.) They say for "medium to large-framed people" because they are the ones who pronate usually. However, I need stability shoes (right now I'm running in the NB 765s), yet I am 5'9" and 125 pounds (skinny as a twig). So don't always go by that description.
One other thing: the 1221 is a high mileage shoe, meant for very long runs and lots of time running. So unless you plan on training 50+ miles a week, you could save some money by going to a slightly less expensive shoe, like the 765 or another brand.
People with high arches are usually either neutral or underpronators (once again I am the exception to that rule). But Stability should still work for most. Many opt for cushioning shoes though, like the Pegasus.
The Nike Pegasus is a great shoe if you truly are a neutral runner and need cushioning. Of course, a lot of how you like a shoe depends on how it fits, so you may in fact not like it, or the 1221 for that matter.
Yellowfiero: the Brooks Beast is meant for "severe" overpronators, and if you aren't, that's probably why you were injured, not because of the sturdier cushioning, although that certainly might have played a role as well.
As for Mizuno, I tried running in the Wave Riders last year, and absolutely loved them, until they gave me ITBS. They are very comfortable, very high quality shoes, but just not for me. I debated buying the Mustang like Amused, but bought the NB 765s on sale instead for $26.
all in all, if you're pretty lightweight, and have high arches, chances are you'll be better off with the Pegasus or another cushioning shoe. (NB has 1022, 880, 752, 725 and 640).
ScoobMaster
2,528
10
I have no opinion/input on which sneaker is better than the other, just thought I would point out that
Finishline.com has quite a few good prices in their clearance section (some New Balance Nike, etc...)
This is just an FYI post :)
Miramonti
28,653
100
I own the 1220's, very stable, very hard compared to any other new balance I've owned (very disappointing).
Granted its not a priority, but they are very ugly when they get a little dirty too.
vi edit
62,484
8,345
Heh. Mizuno used to carry a shoe called the "Sumo Trainer" that was actually geared at heavy runners & hard strikers.
When looking for a shoe here's what I suggest you keep into mind -
1) Your foot type (high arch, flat foot(low or no arch), or nuetral arch)
2) Your pronation type:
- Overpronator: you roll your foot "in" and tend to stand on the insides of your feet. This is usually a result of having flat feet.
- Supinator: you roll your feet "out" and tend to walk/run/stand on the outsides of your feet. Usually done by people with extra high arches.
- Neutral: Generally run with a nuetral motion without putting an excessive burdon on either edge of your feet.
3) Where you strike and the type of striker you are. Do you hit mid foot? Do you hit on the outer edge of your heel? Are you light on your feet? Could you crack concrete with your foot strikes?
If you are an overpronator your foot lacks the arch support to hold your foot up and allows it to roll in. Many overpronators are also running "toes out". Meaning, your feet would point out like the top of "V". Shoes to look for with this type of motion are shoes with a full medial last. The medial last is part of the sole. It's on the inside edge of the shoes and typically runs from heel all the way up to about 3/4 of the shoe. A full length medial last will stop around the ball of the foot on the inner edge of the shoe. These lasts are typically a much harder material and can be reinforced with plastic bridges to prevent flexing of the shoe. A heavy duty motion control shoe is heavy and as flexible as a 2x4.
Supinators need the exact opposite of overpronators. They need as flexible of a shoe as possible to accomidate their high arches. They also tend to run somewhat pigeon toed with their toes more likely to point in than out. Most supinators are generally lighter on their feet than an overpronator...but this isn't always the case. Supinators will generally want to avoid shoes that market motion control and have heavy duty medial lasts.
Nuetral runners get by pretty easy. Most shoes, that aren't specifically marketed at motion control, will work just fine for a nuetral runner. A nuetral shoe may have a small medial last running from the back of the heel to the front of the heel, but it won't run 1/2 or 3/4 of the way like a last built for a motion control shoe.
As far cushioning, only you can be the judge of that. I personally can't get enough cushioning. I destroy shoes in half the time that someone else does because I pound so hard. Thus, I need good cusioning to protect myself. With extra cushioning thier is a tradeoff of stability- the larger the air/gel/whatever cushioning pockets are, the further your foot is from the ground. You loose your connection with the ground and may have a bit of lateral instability because your foot is that much higher up. Try some different shoes on, see what you like. You can tell pretty quick what shoes have high cushioning, and which don't.
Runner's world publishes an annual fall shoe guide every year. In it they have a very detailed breakdown of every runner/foot type with shoe brands and models for each of those types. You can hit a library and try to pull last falls shoe review to see what is available.
I've been out of the shoe industry for a while, so things have probably changed quite a bit. So, if I'm off on my observations please forgive me.
From my experience, Nike generally caters more to high arched or nuetral runners. They do have a "Structure" model aimed at flat footers, but that is one of the few in their product line that is geared twords motion control. Their shoes are generally light because the encapsulated air pockets are lighter than filling it with a more dense foam or gel technology. Their shoes are also much narrower in the heels than many brands. Nike has the best cusioning in the industry IMHO. Definitely the best forefoot cusioning.
Adidas is more aimed at nuetral with a shoe or two for high arched runners and *maybe* one for flatfooted. They are a very nuetral shoe with a wide toebox. They don't have a real marketable technology short of their Adeprene" which is just a soft EVA foam. Their shoes typically have decent heel cusioning, but weak forefoot cushioning.
Asics offer a full line up of shoe types. They have their "Gel Light" line for high archers, their motion control series with a full medial last for flat footers, and then a wide range of shoes for more nuetral runners. Their "Gel" cusioning is their marketed technolgy. It offers decent cushioning and can be put into both heel and forefoot pockets to provide good cushioning in both areas.
Mizuno - I'm not too familar with their lineup any more. We didn't carry them and they are a relatively small player in the shoe industry.
Brooks - more or less cater to nuetral and flat footed runners. Their "Beast" product is just what it says - a BEAST of a shoe. It's big. It's heavy. It's built like an A1 Tank. But it's what an NFL offensive lineman needs to keep his dogs happy when doing his PT.
Saucony - More catered twords nuetral runners and flat footed runners. Uses "Grid" technology. Think of it as a tennis racket in the heel. Your heel is the tennis ball. At the time I was working, they didn't use anything besides basic foam rubber for cusioning in the forefoot. I don't know if they've added anything new since then.
New balance - Their ace up the sleave is that they have the most wide range of widths of any other brand. Narrow, medium, wide, extra wide. You name it. They probably have the best fit of any shoe out there because they can match your foot better. Nothing super fancy as far as cushioning goes - just standard foam rubber AFAIK.
For someone with a nuetral arch and a nuetral gate I'd take a look at the following shoes -
Adidas Supernova Cushion
Asics Gel-Nimbus
Asics Gel-Kumo
Adidas Boston
Nike Air Pegasus
Nike Air Max Moto
New Balance 751/752
That's just what I would have somebody look at if I was fitting them with this specific foot type - and not knowing widths.
If there is any one piece of advice I can tell you - it's this - If it doesn't feel comfortable the instant you put it on, it never will be. Don't buy a shoe that your are indifferent about. Running shoes are either a yes/no thing. You either like them, or you don't like them. When you buy a new pair of shoes, take them home and wear them around the house for a few days before actually running in them. Break them AND your feet in. See if there is any place that is rubbing against your feet, see if you still think they are comfortable. If you are iffy about them, take them back and try something different.
Good luck!
Miramonti
28,653
100
Originally posted by: XZeroII
$138??? You must be a millionaire or something.
or a $138-aire...
I got mine from roadrunner about a year ago when they had 50% any shoe they sell. It was posted in the hotdeals and their sale alotment of 1500 shoes was complete in about 3 hours.
Biggs
3,010
For someone with a nuetral arch and a nuetral gate I'd take a look at the following shoes - Adidas Supernova Cushion Asics Gel-Nimbus Asics Gel-Kumo Adidas Boston Nike Air Pegasus Nike Air Max Moto New Balance 751/752
I'm now a bit confused because the Shoe Dog Finder didn't have any of these in its results. How accurate is it?
Anyway, my inputs are the following,
Gender: Male
US Shoe Size: 10
Shoe Width: Wide Mens 2E
Weight: 131-149lbs
Do you use orthotics: no
Arch Type: Average
Running Mechanics: Unknown
# of days per week you run: 1-2
Miles per week: 0-5
Have you been running less than a year?: yes
Do you wear thick or padded socks?: yes
What is your average training pace per mile: Select One
What is your primary running surface: Concrete or asphalt
Have you had an injury in the past 6 months?: no
If Yes, what type of injury: Select One
Search for Shoes in the Following Brands
These are the results I got,
Asics GT 2090
New Balance 765
New Balance 780
New Balance 806
New Balance 900
New Balance M765WR
Nike Air Structure Triax
Saucony Shadow 6000
P.S.
What about socks? Would the run-of-the-mill with padded heel and toes suffice? Should I look into those "running" socks that have the mesh/vents, ergonomics, moisture wickers, etc.?
vi edit
62,484
8,345
Holy Moly that's a wide foot!
I'd give Mizuno a shot. I know that they tend to run much wider than other other brands. If you truely are a nuetral runner, steer clear of the Structure. They will destroy your feet if you really aren't in need of heavy duty motion control.
As for the ones I listed, that finder may only list ones that are new or current models. I know for a fact that you can find the Supernova Cusion, the Gel-Kumo, the Nimbus, and the Air Max Moto still in stores.
Biggs
3,010
My primary basis for selecting "Wide 2E" is the Hush Puppies Bellville which fits me like a glove. I wear a size 10(US) Wide. Now, I'm not sure what the "standards" of wide is but at least for this brand, their "Wide" version works for me.
Ok, so basically, the Shoe Dog Finder is full of it? I mean, since it still recommends the Air Structure Triax eventhough I selected Neutral Gait
From your previous list,
Adidas Supernova Cushion - Has a wide width version; Best For Small- To Medium-Framed Runners With Medium To High Arches.
Asics Gel-Nimbus - Too Narrow/No wide width version; Best For Medium- To Large-Framed Runners With Medium To High Arches.
Asics Gel-Kumo - Too Narrow/No wide width version; Best for small- to medium-frame build and medium to high arches.
Adidas Boston - Too Narrow/No wide width version
Nike Air Pegasus - Has a wide width version; Best For Small- To Medium-Framed Runners With Medium To High Arches.
Nike Air Max Moto - Has a wide width version; Best for small- to medium-frame build and medium to low arches.
New Balance 751/752 - Has a wide width version; Best for a small- to medium-frame build and medium to high arches.
From here, the Kumo, Pegasus, and Supernova Cushion are the ones that appeal to me(i.e. Has a wide width version; Best For Small- To Medium-Framed Runners With Medium To High Arches). I'm just bothered by the fact that the online shoe finder didn't list them. The former may have been phased out(doesn't appear on the current Asics Cushioned Selection but the latter is very much available(i.e. there is even a 2004 model). If isn't being updated anymore, then at least it would mention the Kumo and vice-versa. Of course, I value your opinion more than a very "generalized" online guide.
Edit: The Adidas Supernova cushion does come in a wide width.
vi edit
62,484
8,345
Well, a suggestion by me or any by an online wizard is simply that - just a suggestion. Your best bet is just to try a bunch on and see what works.
As for what that guide suggests - judging by your build and foot type, I'd look at medium arch shoe for a medium build, which is what it is in fact suggesting.
For me personally, I would feel more comfortable putting a medium arched person in more of a high arched shoe than putting in medium arched person in a motion control shoe for flat footed people. I do not agree with putting someone of your type in the Structure.
As for socks, for the amount that it sounds you'll be running, I'd just buy a pair of comfortable cotton socks from a quality brand like Champion or Wigwam. The fancy "runners" socks might make some of a difference, but you have to be running a long distance to notice the moisture dispertion abilities. I'd just buy a good sock that has a sewn hem above the toes that doesn't rub or blister. This varies by socks and feet.
SWScorch
9,520
Online shoe wizards almost never work correctly. Don;t go by them.
As for socks, I just run in plain old cotton socks from Wal-mart. I only use those high-tech running socks for races, and even then only once in a while. If you get blisters a lot the blister free socks would be a good investment, but if you're like me and don't have a problem with blisters, any sock will do.
And I'll second vi_edit's recommendation of getting a cushioned shoe over stability or support.
btw, vi_edit, you think Mizunos run wider than most? I've only ran in one pair, but to me I felt they were much much narrower than any other shoe I had worn. They hugged my foot like a second sock.
Biggs
3,010
I see. Well, at least my choices now are narrowed down to the "Has a wide width version; Best For Small- To Medium-Framed Runners With Medium To High Arches." I guess it's now time to hit the stores. Thanks for all the help. Cheers!
freegeeks
5,460
go to a specialist store. They let you run on a threadmill and analyze your running style (with video). Then they can tell you what is your ideal running shoe.
I also alternate between 2 different pairs of asics
sygyzy
14,001
4
What are some nation wide chain stores that have the tools and know-how to help someone choose a running shoe? I want a store that can look at how I walk/run and make a recommendation on that. I am not talking about Footlocker, but something more akin to Runner's World. Any others like that?
SWScorch
9,520
Fleet Feet is great for that kind of stuff. They usually have a treadmill set up with a camcorder for gair analysis and they're very knowledgeable.
Instan00dles
1,174
Nike actually makes decent shoes? I have always been under the impression that they are horrible shoes. I was going to go get some of the new 1221's from the shoe store but unfortunatly they did not have my size in stock (9.5 4E):(
Flyermax2k3
3,204
I'm too lazy to read the whole thread. Can you buy these shoes retail or do you have to buy them online? I was thinking about getting into running to stay in shape (I'm getting lazy) and was wanting to get some new shoes. I've got two pairs of running shoes now but I mostly have basketball shoes and dress shoes plus the running shoes I have are at least 3 years old, each. I'd like to get some new running shoes that are comfortable and will last for a long time.
Does anyone know if there are any running shoes one can purchase at say, Footlocker that would be comparable to these shoes? If so, perhaps I'll go to the mall today and pick up some new shoes and see a movie or something.
