Originally posted by: RossMAN
What kind of warranty does the Dell 1900FP carry?
3yr. i believe
Ross, are you thinking about getting this monitor as well? I got on this deal couple weeks ago, this monitor is basically the same size as my old Sony 21" G500 🙁. Its huge. i'm very pleased with the quality of the 1900FP. I'm cutting back on my lunch money to get this monitor 😛 but its worth it.
--Scsi
All Dell system flat panel monitors are covered by up to a 3-year limited warranty and backed by Dell service and support
Originally posted by: Kingofcomputer
The keyword here is "system" flat panel, that means you buy with system, you get up to 3 yr warranty, since system could have 1 yr, 2 yr or 3 yr warranty.
Originally posted by: bluesky
People, take look at your manual came with the lcd.
Here is a linky for people who already tossed it to a garbage can.
1900FP Manual
1900FP Manual
Originally posted by: boggsie
I use 19" CRT's at 1600x1200 resolution. I am considering moving to a flat-panel, but from what I can see, 1280x1024 is the maximum resolution that they support. I don't understand this. The flat-panel actually has more real-estate to work with, but the resolution is limited for some reason.
Am I missing something or does this seem strange?
Originally posted by: Schnieds
Ascetics:
Winner: Dell 1900FP
I love the tiny silver bezel on the 1900FP. It just looks darn cool. I also perceive the 1900FP to be a little bigger (optical illusion only) than the 191M because of the smaller bezel. The 1900FP rocks! I should not however, that I had a friend over to check them both out and he liked the look of the Planar better and felt it looked bigger, so this is very much personal preference.
Flat panel displays are all set up like a grid. Unlike CRTs, which have 1800 or more physical pixels, virtually all 14" and 15" panels are 1024 physical pixels wide and 768 pixels high. This is why all vendors of flat panel displays suggest using the 1024 x 768 resolution exclusively for 14" and 15" panels. By the same token, the best resolution for 18" panels is 1280 x 1024, because of their physical size. Using a lower resolution such as 800 x 600 reduces the physical pixels to the center 800 x 600 pixels in the middle of the display; making the viewing area significantly smaller or using a smoothing algorithm to strectch the image, degrading clarity.
from Hitachi
Ascetics:
Winner: Dell 1900FP
I'm fairly certain that you meant "aesthetics" and not "ascetics". Unless you're into self-denial. 😀
Just wanted to re-iterate how much of a difference DVI makes over a VGA connection. I just got another new DVI card to replace the VGA card I was forced to use for a while... it's like night and day. 😉
