You should get that 8800 GTS problem figured out, it's way better then the X850, and you already have it....
I wonder if I might be having an issue because my PSU is underpowered, it recommends 400w and I have 300w psu?
The 6850 looks like a great card but it requires a 450w power supply.
I'll give driversweeper a shot.
I think my best option may be to try the 5670 and driversweeper.
I also think that certain cards may be better optimized for this older sim and bigger, faster and more expensive may not always be better.
You don't need another card if you have an 8800 kicking around. You need a better psu most likely. Honestly that would be the best money spent and allow for future upgrades
So I got the card yesterday and it seems to be ok. After a couple of tweaks it seems to be on par with my x850xt perhaps around 5% faster and my Windows score went from 4.9 x850xt, 6.7 8800gts to 6.8 5670.
At the end of the day it's a very quiet card with ample power, I'm not at all blown away with the improvements from 5 years ago but I am satisfied. It does appear that the sim is either software capped or these newer cards just aren't optimized.
Thanks again for all your help,
Tom
Good to hear. You know, I wouldn't be surprised if that 2003 game is CPU-limited, or the video drivers just aren't designed for games of that vintage. A lot has changed about the way graphics are rendered since 2003.
Your card is obviously functioning correctly, since the WEI went from 4.9 to 6.8 (and was right where I thought it would be, essentially tied with the 8800gts). Perhaps you didn't need the upgrade for the game you play, but for other games, I promise you it will be much faster than the x850xt, and it's cooler, quieter, and uses less power too. Perhaps you should invest in a new racing game just to see what the card can do. F1 2010 maybe?
