- Feb 19, 2001
- 20,155
- 23
- 81
I reconnected everything after doing a full blown cable management revamp and then I didn't like how my fan controller wasn't screwed in well. Pulled it out and rescrewed the rails in which required unplugging the cpu fan from it. Whoops. I turned my comp on and played 10 min of Hitman and then the system shut down. No, I didn't have any bugs or any errors, but rather my shutdown temperature kicked in.
I set it at 60C in BIOS but CoreTemp which is more accurate in checking temps usually reports 3 - 4 C above. I've never even broken 55 on this CPU except for stress testing on a hot day. Usually I load around 44 in Mobo Monitor, but CoreTemp can report up to 50.
Hope I didn't damage anything ><
Edit: Rig is an Opteron 170 running at 2.6 GHz
