United flight has severe engine uncontained engine failure
Zorba
15,613
11,256
Wonder why the pilots didn't snuff this one out considering the amount of damage.
What do you mean snuff it out? I'm sure they pulled the fire handle, which shuts off all the flow of fuel and hydraulic fluid to the engine. But the halon wouldn't have put out the fire with the nacelle missing as the halon would've just been blown away. This looks like it was probably residue flammable fluids (fuel and/or oil) burning and the thrust reverser diverters burning.
Zorba
15,613
11,256
That video above, that's a pretty nasty shimmy. I wonder what it looks like when it reaches the shear bolt level?
WIndmilling loads after a fan blade out are the maximum design loads for some of the structure, so it is a pretty big deal.
Zorba
15,613
11,256
In the videos I don't see any missing fan blades, and I don't think there is enough damage for it be a rotor burst. So I'm very interested in what caused this issue. From other pictures, the nacelle didn't compeletely fail at once. It lost the nose and fan cowls first, then shed the thrust reversers later.
Reactions: Paratus
BUTCH1
20,433
1,769
Yea, after watching it a few times this seems the most plausible, fire suppression would have to arranged to flow from front to back and with that cowling completely gone from the front any ability to do that would have been gone. The fire is dying down as the video progresses too.
skyking
22,808
5,973
That's a hell of a shimmy for an intact windmilling assembly. Something (s) have to be bent or missing. We'll know in 6 months when the NTSB releases the report ;)
Zorba
15,613
11,256
Yeah, I agree something is out of balance. So something in the engine broke, just not sure what. If the NTSB gives some initial information the what will probably be clear with a week or two, the why will be much longer.
Meghan54
11,684
5,228
Definitely some parts of blades missing in this pic:
BB1dRN6z.img
hal2kilo
26,280
12,444
Must have been a rather "bad" engine failure as I've been lead to believe the engine's cowling is designed not to disintegrate when an engine fails like this one did. Supposedly supposed to contain the "failure" and not shred like it did. And it's United, so that's not a surprise.
Thank goodness it appears no one was killed on the ground. And the cowling's front outer ring...damned lucky it landed how it did.
Must have been quite the compressor stall to push the front nacelle cowling forward against the wind.
skyking
22,808
5,973
I used to inspect nacelle assemblies for the Fokker 100 and Gulfstream GIV at Hexcel. They are much, much smaller, but definitely built hell-for-stout.
hal2kilo
26,280
12,444
Thanks for the still. Definitely looks like a fan blade out now. The nacelle shouldn't come apart from that, but there has been a rash of nacelles coming apart after fan blade failures.
Seem like they still haven't perfected the casting of the titanium billets for the fans. That has been the cause of drastic fan failures before, but this fan is largely intact minus a few blades. Probably be a year or so before they figure this out.
Zorba
15,613
11,256
I've never worked these engines, but I am pretty sure that these are hollow titanium fan blades and that they are life limited parts. So one failing in flight is a big deal.
Looks like United is grounding all of their 777s and the FAA is looking into issuing an immediately adopted rule (AD) against the engine type.
Meghan54
11,684
5,228
Indeed they are hollow fan blades, according to the tweet the FAA put out regarding the grounding/inspection for the P&W engines. FAA says in the tweet these "hollow fan blades that are unique to this model engine, used solely on Boeing 777 airplanes."
Reactions: Zorba
