Unigine Valley 1.0 Benchmark Thread ** Post your scores**
Cookie Monster
5,161
32
86
I don't usually do this but I want to contribute to the thread!
2500k@4.5GHz, GTX680@ 1202MHz/6500MHz using latest drivers (314.22).
edit - you should divide the table with different resolutions.
Face2Face
4,100
215
Scorer for my 3770k rig below:
Hey Gus, I need your clocks for all three rigs. Thanks!
Thanks for your contribution :thumbsup:. I am going to keep it @ 1080P for now. Seems this resolution is what the majority of our members are running and it's resolution for the built-in preset.
guskline
5,338
476
Sorry Face2Face, I hope this helps.
For rig 1 below, it has a 3770k OC'd to 4.4 Ghz with 2 identical EVGA GTX660 FTWs in SLI stock clocked as follows: Base 1006 Boost 1084
For rig 2 below it has a FX 8350 OC'd to 4.6Ghz with a single PNY GTX680 stock clocked as follows: Base 1006, boost 1058
Finally, not listed is my third rig, a FX 8320 OC'd to 4.3 Ghz with Asus Sabertooth 990FX rev2 mb, and 2 GTX 660s in SLI all stock clocked, First GPU is MSI TF OC base 1033 and boost 1098 and second EVGA GTX660 SC base 1046, boost 1111.
All test results were with these clock speeds. Hope this additional info helps!;)
Dankk
5,558
25
AMD Radeon 7870 Pitcairn 1100/1400
AMD FX-8350 4.4GHz
Catalyst 13.4 WHQL
AdamK47
3,638
Titan 3-Way SLI with my everyday stable overclocks.
+78 core (13MHz x 6) and +100 on the memory for each GPU. No voltage adjustments. At load, the boost settles to 1019MHz for GPU1, 1032MHz for GPU2, and 1058MHz for GPU3.
320.00 drivers with everything set to default. Rest of the system specs in signature.
guskline
5,338
476
DooKey and AdamK47: When I see both of your scores I see myself next to Wayne and Garth screaming "I am not worthy, I am not worthy . . . ":biggrin:
Kenmitch
8,505
2,250
Factor in the $`s per point and your way ahead of them :)
Belkov
143
GB 7950 WF3 @ 1260/7480 with 13.2 beta 6 drivers.
This is only for benchmarking... i can't use these settings for gaming.
Lepton87
2,544
9
Very unimpressive scaling, I get almost 70fps with one Titan and you can't break 140 with 3. When I tested my 4-way CF set-up in unigine tropics I got almost perfect scaling up to 3 card and 25% for the forth.
AdamK47
3,638
I apologize.
guskline
5,338
476
Revenger: In your sig you have "EVGA GTX 780 SC". Is that "wishful thinking" or do you actually have one?
Face2Face
4,100
215
Updated:
Come Red team, I need to see some more Crossfire scores on this thread..
Green team is embarrassing you :$
MTDEW
4,284
37
Well fine then, here ya go. ;)
7950 x 2 - 1200/1500
(note: had to up pwr tune above +20% to keep my cards from throttling in this particular benchmark at anything above 1125 core, not sure why since +20% is usually enough in any other benchmark/game)
Anyway, here is my pic.
