- Sep 28, 2005
- 20,846
- 3,190
- 126
Standard multiplier is 21
4 cores turbo 22
2 cores turbo 25
1 core turbo 26
So it's more than just 1! It should go from 21 to 26 in principle the way I see it at least... no turbo activated should be 21 no matter how many cores, and 3D mark 06 I would imagine only uses 1 core? This should up the multiplier by 5 to 26 + enable turbo mode...
No, both Vantage and 3d06 use multi cores.
I have both @ 30k scores if u want to see them... :X
38k cpu on vantage.. and 8k cpu on 3d06.
I have no idea in your problems, im now pointing it to HT being ON/OFF... if your really that skeptical an easy solution would be this:
Use the 22x multi and just OVERCLOCK your system to 3.46 (Bclk of 157) you will need to tweek voltages, which isnt relatively difficult to do provided you have a decent aftermarket sink.
Then run the tests and see if u can get relatively close to the original 3dmark score.
(im wagering you will get higher, because of the faster ram timings u now induced along with the lower qpi latency you will have from that bclk adjustment).
But im fairly sure 3dmark is multicore'd.
I get a higher score on my gulftown vs bloomfield @ a higher clock.
EDIT:
Wait once u play with blck dont you lose turbo on?
For turbo on to work, you need your board set to AUTO.
Otherwise you wont see any multi over the +1.
