Discussion Undiscovered planet beyond Neptune (to be confirmed within next 3 years)
marees
1,954
2,581
when the Vera C. Rubin Observatory goes online sometime in 2025, one of its missions will be providing unprecedented clarity into what lurks beyond Neptune, potentially revealing 10 times as many Solar System objects as are known today.
For centuries, astronomers have been shining a flashlight, hoping to stumble upon a cosmic mystery in the darkness. Hopefully when the Vera C. Rubin Observatory finally arrives, it’ll be like turning on a light switch.
GodisanAtheist
8,384
9,769
-Whoa the subheader on that link is really overselling Planet X IX...
deadlyapp
6,671
744
Do you have stock in this observatory or something? Jesus you spam the exact same message in near every post.
marees
1,954
2,581
Just hyped for planet !X
& yes the LSST Observatory will definitely confirm the existence (or absence) of planet nine
So expect more posts on this line in future
Ken g6
Moderator
Dec 11, 1999
16,715
4,672
75
Pluto is a planet, dammit.
Obligatory XKCD:
Personally, I think planet should be defined as an object with enough mass to retain an atmosphere not orbiting an object that is not a star. (Where "orbiting" an object means the combined center of mass is entirely inside that object. If two objects of similar mass orbit each other you can have a double planet.) This would mean Mercury is not a planet either. :smilingimp:
marees
1,954
2,581
The observatory will be a game-changer in the hunt for Planet 9, agrees Scott Sheppard of Carnegie Science, one of the researchers who first suggested that a big planet could be the culprit that was messing with the orbits of some small solar system bodies.
"Vera Rubin is our best bet to find it in the next few years, probably," says Sheppard. "It's going to turn over more rocks than anyone has turned over before."
If Planet 9 is real, this observatory has around a 70 to 80 percent chance of finding it, he estimates, adding that it's not a sure thing because there are so many uncertainties.
"We don't know the size of the planet. We don't know the reflectivity of the planet. We don't know the distance of the planet," says Sheppard. "Those three things will determine how bright this planet actually is."
If Planet 9 is on the smaller side, dark, and really far away, he explains, "it's going to be on the edge of Vera Rubin detection, and Vera Rubin may not find it."
But even if it doesn't spot Planet 9 directly, the Rubin Observatory might find some more minor planets, ones whose orbits might be affected by Planet 9. And that could provide additional evidence that such a giant planet really exists.
Up until now, says Sheppard, astronomers haven't found enough small, far-off minor planets with orbits that can be analyzed for evidence of Planet 9's gravitational influence, so he thinks the existence of this planet is an open question.
"The statistics just aren't there to definitively say yes or no," he says.
19,203
At an estimated distance of 700 AU, I don't see why they call it a planet. In fact, I think it's silly of them to want to include bodies beyond Neptune as part of the solar system. There could be thousands of rocky planets circling the sun, in almost pitch darkness. What would be the point of getting to know about them?
Reactions: marees
marees
1,954
2,581
The Kuiper belt, whose population and structure are only vaguely known, stands to be greatly illuminated by Rubin. After nearly four decades of searching, astronomers have found about 4,000 objects out there. “With Rubin, it should go up to about 40,000,”
[DHT]Osiris
17,410
16,709
If it orbits our star, it's part of our solar system, that's the actual definition of a solar system. If it fits the definition of a planet it should be called one (and vice versa).
19,203
Technically yes but at something like 700AU, is the Sun's gravity strong enough to matter? Maybe the unknown planet is just barely orbiting the Sun because what else it gonna do? It doesn't have thrusters to fly away or into the Sun. The definition should be revised with regards to the AU distance where the Sun's gravitational pull is strong enough to keep the planet from ever breaking free. If planet 9 is indeed exerting a significant influence on the Kuiper Belt objects, then that's kinda laughing in the face of the Sun and going, "Haha! You so weak that I'm messing with the objects orbiting YOU!".
[DHT]Osiris
17,410
16,709
Of course it is, if it's still in orbit the sun's gravity is very actually strong enough to matter, just like every other object orbiting our star.
marees
1,954
2,581
Planet 10 ??
research, posted this month to the preprint server arXiv and set to publish in the Proceedings of the Astronomical Society of Australia, comes from a group of scientists in Taiwan, Japan, and Australia. The group pored over archival data from two infrared space telescopes, NASA’s IRAS mission from 1983, and Japan’s AKARI satellite from 2006 to 2007. Their goal: find any object that’s cold, faint, and slow enough to be Planet Nine.
"interesting point is that the orbit of this object is not consistent with our predictions for Planet Nine,” Brown added. “That doesn’t mean it is not real, just that if it IS real it is not the predicted Planet Nine, it is something unpredicted.”
“My suspicion is that it is simply noise, but it will be fun to find out,” he said.
marees
1,954
2,581
In a study led by Terry Long Phan posted to the arXiv preprint server, the team searches for Planet Nine candidates by using two far-infrared all-sky surveys, IRAS and AKARI, whose 23-year separation allows detection of Planet Nine's expected orbital motion (~3′/year). The search uses the AKARI Far-Infrared Monthly Unconfirmed Source List (AKARI-MUSL), which is better suited for identifying faint, moving objects than the standard AKARI Bright Source Catalogue.
Researchers estimated Planet Nine's expected flux and motion based on assumed mass, distance and temperature, then applied positional and flux criteria to match sources between IRAS and AKARI. They identified 13 candidate pairs with angular separations corresponding to heliocentric distances of 500–700 AU and masses of seven to 17 Earth masses.
After a rigorous analysis and selection process, including visual inspection of images, the team identified one strong candidate pair, where the IRAS and AKARI sources showed the expected angular separation (42′–69.6′) and were not detected at the same position in each survey. The AKARI detection probability map confirmed the candidate's consistency with a slow-moving object, showing two detections on one date and none six months earlier.
However, IRAS and AKARI data alone are insufficient to determine a precise orbit so there will need to be follow-up observations to confirm the candidate and fully determine its orbit using DECam, which can detect faint moving objects within about an hour of exposure, aiding in understanding the solar system's evolution and structure.
marees
1,954
2,581
if the researchers are right, their planet would disprove the original planet. They would make each other’s orbits unstable and could not exist together, he explained.
“It’s kind of fun that a paper that purports to find a candidate for Planet Nine is really finding something that would basically say that we were wrong the entire time,” he noted.
marees
1,954
2,581
Based on how bright the object appears in both datasets, the researchers estimate it could be even more massive than Neptune. That’s surprising because the team was originally looking for something smaller—maybe a super-Earth. Yet, it fits the expectations for Planet Nine‘s estimated mass and distance better than anything found so far.
marees
1,954
2,581
It appears in one position in IRAS's 1983 image, though it was not in that position when AKARI looked. However, there is an object seen by AKARI in a position 47.4 arcminutes away that isn't there in the IRAS imagery, and it is within the range that Planet Nine could have traveled in the intervening time. In other words, this object has moved a little further along its orbit around the sun in the 23 or more years between IRAS and AKARI.
The knowledge of its motion in that intervening time is not sufficient to be able to extrapolate the object's full orbit, therefore it's not yet possible to say for certain whether this is Planet Nine. First, astronomers need to recover it in more up-to-date imagery.
"Once we know the position of the candidate, a longer exposure with the current large optical telescopes can detect it," Phan told Space.com. "However, the follow-up observations with optical telescopes still need to cover about three square degrees because Planet Nine would have moved from the position where AKARI detected it in 2006. This is doable with a camera that has a large field of view, such as the Dark Energy Camera, which has a field of view of three square degrees on the Blanco four-meter telescope [in Chile]."
Indus
16,359
11,295
Looks encouraging but I don't think we're going to get images of it in our lifetimes.
I mean Voyager 1 is 167 AU away after travelling almost 48 years.
So if this thing is 700 AU.. it'll take about 200 years if we start today unless we find a faster means of sending probes.
Reactions: marees
