- Oct 23, 2000
- 9,200
- 765
- 126
I recently put together a Ryzen 9 3900X system with a Gigabyte Aorus X570 Elite Wifi motherboard, 32 GB of G.Skill RipJaws 3600Mhz CL16 RAM, and a Scythe Fuma 2 cooler. (plus my previous SSD and an EVGA GTX 1060 3GB)
Overall I'm very happy with the performance results. However, it's starting to get warmer here, and the already somewhat high temperatures in the system are just going to go higher as summer progresses, so I'm looking for the most efficient way to reduce heat without losing too much performance.
I already undervolted the GTX 1060 using this guide and dropped full load temps on the GPU by about 8C, which is a great start as it not only lowered the temps but actually boosted the GPU benchmarks a bit as well since the card was throttling itself a bit and not boosting all the way up to 1911MHz before the changes...
I'd really like to do something similar with the CPU if possible. Don't mind if I lose a small amount of performance if the temperature drop is good enough. Boosting performance and lowering temperature is probably too much to ask for on the CPU. I've found quite a few guides online for undervolting the CPU, but there are so many different options, and some of them seem to be excessively complicated and/or have pretty questionable results, so I'm hoping to get some good advice here.
It seems like the easiest option would be to simply lower the PPT to something below the stock 142W maximum, and with some trial and error I can probably find a suitable setting. But if there are better options, I'm definitely open to suggestions.
