Originally posted by: BadThad
Interesting....first I've heard of that....thanks.
Hey Assim1! Thanks for starting this thread, now, get them to fix it. 😀
Heh!
I've used TinyURL addys in my sigs (here and elsewhere) for a long time... For instance, I have a Google Search feature in my sig that searches for results on the AnandTech web site only. This would be impossible without TinyURL (or clones) because the URL is 100's of characters long...
Anyway, until 'they' fix the edit feature for System Rigs, all you can do is make a new one. I did this last night.
Here is my *edited* system rig [see the link in my sig].
This is quite easy if you use Firefox as your browser...
Bring up the page for adding system rigs in one tab, and the page for viewing your system rig in another tab.
If all you want to do is edit your existing rig, use it as a template, and copy n' paste the lines from the viewing page, to the form in the adding page.
When you get done, hit the submit button in the adding page, then click the back button in your browser. That will take you back to the adding page, with all the newly entered info still in the form.
At this point, look at your results by viewing the new system rig that you created, using the viewing page in the other tab. If you don't like the results, simply delete it from your system rig, go back to your adding page, in the other tab, make adjustments to the info in the form, and submit it again.
Repeat this adding, viewing, submitting, and deleting process until you get the *new* system rig to your satisfaction...
When you're done, you will end up with a different URL, because the system rig number, in the AT database will have changed. Use this new URL in your sig, and/or make a new TinyURL addy, and you're home free...
I know this is a PITA, but at least you won't have to kludge up your sig by entering all your system rig info there!
