Originally posted by: AWhackWhiteBoy
its not quiet? are you friggin nuts? its 140mm fan spinning at a max of 2200RPM, and its adjustable so you can make it run slower. it puts out a max of 28dB, 24 on low speeds. if you want a quieter PSU buy earplugs.
Originally posted by: smoothness
go to silentpcreview.com they have new reviews on the seasonics, which run on 120s. i think that'd be a good choice. oh yeah - i have the cooler master centurion [same type of case] if you manage to switch out all of your 80s for some panaflos, that might help too. b/c my four coolermasters make a heck of a lot of noise.
Originally posted by: Tiamat
I would probably:
Seasonic Super Tornado 400
If you have 80mm Case fans, Panaflo L1A @ 5-7V
If you have 120mm Case fans, Globe 120mm @ 7V or Nexus 120mm @ 9V
If you have 92mm fans, Panaflo L1A @ 7V or Panaflo M1BX @ 5-7V
Arctic Silencer NV5 for your graphics card w/ Zalman fanmate to lower fan RPM
My point is, that upon obtaining a very quiet psu, you get to be annoyed by your system fans and gpu fans that seem quiet now, but really are just slightly quieter than your loud psu.
I would probably:
I have the artic silencer on my card, i love it. Is the zalman fanmate worth picking up?
I would probably:
