yankeesfan
I am starting to work out and I was wondering if I should be doing lighter weights with more reps or less reps and more weight. I am bulking.
Just starting out I would suggest 10-12 reps to failure until you get some experience in proper form and full range of motion.
After a few months, you can step that down to 8-10 reps, then to 6-8 reps.
Thanks, I'll do that.
Just remember, the key is to give every set everything you've got and work to absolute failure. If you can do more reps than your max rep range using proper form and full range of motion, add more weight. If you, and/or your form fails before your minimum rap range, take weight off.
To find out proper form and full range of mothing, consult this site:
http://www.exrx.net/Lists/Directory.html
Now, if I get to a point before my last set when I can do no more at all, should I lower the weight or give myself more time to recover?
Last set, or rep? Last set of the workout?
Weight is flexable. Do not get married to your weight numbers. What matters is your rep range, form, and range of motion.
If I do three sets on the flat bench, chances are my last set will be a little lighter than my first to keep me with my rep range. Unless, of course, my first set exceeded my rep range, and I then added weight.
OK, got it. Thanks.
