Ultimate Body Press
purbeast0
53,765
6,645
get him a gym membership instead.
all of these "work out equipment" items are gimmicky pieces of crap.
why do you think no gyms have any of these exercise items sold on informercials? cause they are worthless.
SirJangly
680
Well we have a $5000 smith machine, and a gym quality bike and treadmill. These were bought from a company who provides them to "gyms." The only issue is a lack of dip bars on the smith machine, which is why I'd want this.
RagingBITCH
17,618
If you have a $5000 smith machine, surely you can buy a $150 dip/pull up/hanging leg raise tower. It'd be way better than that piece of crap.
Cattlegod
8,687
you can just scoot your washer and dryer close for dips. i wouldn't bother with this.
Cattlegod
8,687
There ya go.
SirJangly
680
True about the tower, but the new smith machine is HUGE, and I'm not sure if there is room for a tower in the 2nd garage...the appeal of the UBP is it's size :) Well, obviously lol
SirJangly
680
Originally posted by: chalmers
Smith Machines are garbage.
Care to elaborate on that statement? I'm sure if you buy an $800 model from Big 5 it would be, but I'd have to disagree from experience with the higher quality models.
Howard
47,986
11
Free weights are better.
Mar 22, 2002
10,483
32
They are garbage in the sense that you should only use them if you are injured (usually back injuries) because they isolate your body on a single plane. Your body needs its stabilizers and that's why free weights are much better and safer (especially for athletes). If you aren't injured and you use the smith machine, then you are definitely hurting your progress. Get a gym membership and start doing barbell squats - much healthier.
SirJangly
680
I do use free weights when I can. This particular model does not isolate, as the weighted barbell not only goes vertically but horizontally as well. It's pretty awesome actually, and much safer if you work out alone.
BeauJangles
13,941
Not true at all. Any sort of guides will take away from the need to use your stabilizer muscles and will prevent you from having proper (freeweight) squatting form.
The safest way to squat is to do so in a power rack.
gramboh
2,207
Yeah those two plane ones are still inferior to a free weight exercise, you are not stabilizing the weight anywhere near as much as you do on a free weight squat etc.
As far as the linked item goes, it looks really annoying to use, I would not want to do weighted dips that close to the ground and be forced to kick my legs so far behind me, plus on a full range of motion the plates on the weight belt will hit the ground for sure, in the pic the guys got a small 25lbs plate or something and is not even close to full ROM and it's near the ground.
Can't believe a $5k machine doesn't have a real pull-up bar or come with a dip attachment. For $5k you could've bought a nice power rack w/ pull-up bar, lots of nice bumper plates, oly bar, dip bars, bench, rings etc etc. Return the smith if you can.
Mar 22, 2002
10,483
32
Wrong. Like BeauJangles said, a power rack is safe (perhaps SAFER since you can bale it backwards and not get crushed) and is also better FOR you. You ARE NOT - I repeat - you ARE NOT developing your stabilizers at a rate to keep up with you practical squatting weight. You're setting yourself up for injury. For example, if you wanted to pick something heavy up or wanted to run explosively, you increase your risk of injury since your ligaments and small muscles have not adjusted to a real life load. Please don't fool yourself.
SirJangly
680
It actually has an amazing pull up bar, just not one for dips. What is this power rack you guys speak of?
spamsk8r
1,787
A power rack (see Image) is the standard squat cage. It allows a trainee to do full range of motion squats without having to worry about bailing on the weight. This is as opposed to just a squat rack, which doesn't have the full cage action going on. If I had room for a home gym this would be the first thing I bought (after an Olympic barbell and bumper plates, of course).
