Uhh Holy Crap!?
Originally posted by: ilkhan
Best case they'll work but be slower. But, while they should work solo, I doubt they'll work in a two way configuration.
no they WONT work at all.
Because those boards need 2xqpi
Bloomfield is 1xqpi
Gainestown is 2xqpi
I know a couple of sites mentioned the possibility of a xeon+2xX58 board, which really WOULD have native quad x16 slots. That could be impressive. But these prices just plain suck.
You mean the next gen Skulltrail? I think intel can'd that.. Well then again i hear of a X5590 (assume 4gs for the pair) which is suposed to have an unlocked multi and a D0.
GUYS STOP DREAMING DO I NEED TO GET A STEAM ROLLER AND ROLL OVER YOU GUYS.
GAINESTOWN 2xQPI WILL ONLY WORK IN STOCK ON BOTH BOARDS.
OVERCLOCKING BLOWS ON A GAINESTOWN CPU ON A x58 BOARD.
AND NO BLOOMFIELD EVER WILL WORK FOR A GAINESTOWN BOARD.
i7 brings new rules including Xeon Chips. And NO they dont work very well on our X58.
And yes ive tried, and i think gillbot is tired of hearing me complain about a Gainestown in a X58 board.
You guys just wait and see. Wouldn't it be great if intel played smart ass here, On that 2 core model . Be cool if 1 f the 2 none functional cpus worked. Like some AMD 3 cores run all 4
On the Ram thing Doesn't the ondie memory controler for intel except more than 1 kind of DDR3 . It should . So that little 2core jobe should go into Desktop 1366.Socket and work with M/B memory. Intel puts same controler in all Nehalem Cpus do they not. The second link should not matter if not used.
That 2 core baby I would like to see with HT. I bet It be ass kicking little crippled up cpu.
Originally posted by: PlasmaBomb
Originally posted by: speedfreak
xeons aren't meant for overclocking afaik or are they?
Nope, they are ment for stability.
which is why they and Opterons have made for incredibly good overclockers at various points in the past as they're generally held to a higher standard
obviously if they're purposefully crippled against being tampered with and/or are platform limited they won't be very good overclockers, if overclockable at all
Bloomfield is 1xqpi
Gainestown is 2xqpi
You dont think its *possible* for inter-CPU communication to go through the northbridge?
Bloomfield is 1xqpi
Gainestown is 2xqpi
explain...
you need dual qpi pathways for 2 cpu's to work in a pair.
Intel designed them like this.
http://i125.photobucket.com/al...igomorla/Capture-1.jpg
Now google a standard P6T-Deluxe Bios option and compare it to mine:
http://i125.photobucket.com/al...aigomorla/IMG_0162.jpg
You'll understand after that.
So, are there any significant advantages to a Xeon compared to a similarly clocked desktop chip ( that justify the price premium)..?
Bloomfield is 1xqpi
Gainestown is 2xqpi
explain...
Here you go:
http://www.techspot.com/articl...129/images/BIOS_01.jpg
