Originally posted by: silverpig
Use player to play the tracks one by one, and your sound card to record the "what you hear" output.
Ding Ding Ding!
Winar!
I don't see how it is possible for an audio Cd player to play a cd flawlessly, but a cd-rom will fail to The error correction is all in the hardware, not the software, isn't it?
Not quite. The difference is what happens when the an 'uncorrectable' error is encountered.
Protected CDs contain many thousands of uncorrectable errors which are deliberately inserted during recording. On a PC the drive will send what it could read and verify, along with a message saying whether the data is correct or not.
On an audio CD player, if the audio decoder receives a message saying the data is incorrect, the decoder will attempt to fill in the gaps with what it guesses will sound OK (it interpolates between known good areas).
Rippers simply get the sound with the raw data, and an error count, but don't know which bits of data are the errors, so can't cover them up.
If you are fortunate enough to have one of the very rare CD-ROM drives that can interpolate while ripping then you should be able to rip the CD straight off (if you use 1x ripping).
If you don't, then to copy it you'll need to play it in analogue mode, and record the analogue signal with your sound card.
Originally posted by: Chadder007
Sue Sony BMG for crashing your PC = the WiN!
Originally posted by: sheik124
It is not new copyright protection, its the same old sh!t. EAC worked just dandy on Linkin Park - Meteora, which was "Copy Protected".
Originally posted by: magomago
isn't there some software that it secretly installs on your pc as well?
Originally posted by: 0roo0roo
return it. do not support such tactics. they are effectively sh*tting in their paying customers faces. it has no impact on real piracy
Originally posted by: cchen
Originally posted by: JonTom
isobuster is your friend
damn... ripping it with isobuster... the files are distorted![]()
don't rip it - just browse the disc and find the wav files, copy them to your HD, and then LAME em.
Yep, if you have auto-run on even once with the CD it'll install a device driver without telling out. After that you can't rip the disc, without at least disabling the ninja device driver.
The link provided above shows show how to disable the device driver.
Originally posted by: Tab
Disable the auto-run? Try that.
huh?? to play the cd.... u have to use the player on the cd
no
1. Will this disc play on my computer?
Yes. This disc is compatible with both PC and Mac.
PC Users: When listening to music directly off the disc, you must use the player provided on the disc. Attempting to play the audio on the disc (while the disc is spinning in the computer drive) with another player (i.e. Windows Media Player, Real Player, iTunes) will result in distorted sound.
Originally posted by: myusername
eac?
same thing.... distorted crap
