PSU was a 550W rosewill. It had 26 A on the 12 V rail, which I thought was more than sufficient.
I was running an Athlon 64 3000+ (single core, oced to 2550 mhz), 2 hard drives, 2 opticals, and an x1900 xt (oced to xtx levels).
The PSU was rock solid for over a year. I left it running atitool 3dtest, and went off to the gym. When I came back my PC was off. I pressed the power button and it sparked and flashed out. You could smell the burn.
I inspected the graphics card, and there's no visible damage to it, and it doesn't look like anything has happened to the motherboard either. I don't have another rig to test anything out though.
ATItool labeled the card as drawing 28 amps on its own. Is this accurate?
What are the chances that I damaged anything else? And what's a good PSU replacement?
My motherboard is the DFI Ultra-D Lanparty, so it takes a 24 pin, the 4 pin connector on the side, a standard 4 pin molex, and a floppy connector.
