Ubuntu help
HybridSquirrel
6,161
So I loaded up the ubuntu 8.10 installer and installed with wubi...installation went smooth and when i rebooted there were 2 ubuntu selections. 1 works. the other brings up some error messages. Is there a way to remove the one that doesnt work? if i have to clear off the one that does work thats fine i can try to reinstall. i have major ocd on stuff like that.
edit: after reading my own post...would i have to run windows system recovery?
gcy
728
google "edit grub" and it'll give you directions on how to edit grub and change loading options.
Dec 10, 2005
29,740
15,344
The only time I've ever had the two Ubuntu options is when the kernel updated. I guess it doesn't update the Grub file on its own, so you'll have to do what gcy said.
Nothinman
30,672
Are the extra options part of NTLDR or GRUB? I wouldn't think that WUBI would install GRUB but I've never done it myself.
Colt45
19,720
/boot/grub/menu.lst
near the end of the file... take off the one that doesn't work.
VinDSL
4,869
www.lenon.com
Originally posted by: Colt45
[Edit] /boot/grub/menu.lst
Correct answer! :D
It never fails to amaze me how little ppl know about Linux!
And, this isn't directly toward you, Colt45, obviously...
