Open Ubuntu Software Center under Applications. From there search for "Ubuntu restricted extras". Click install and once it's done you should be good to go.
Can someone tell me the difference between the 3:
Ubuntu
Xubuntu
Kubuntu
Thanks. Which is better for a novice?Ubuntu comes with Gnome
Xubuntu comes with XFCE
Kubuntu comes with KDE
Different window managers
The easiest way to get things working in Ubu is to install "Ubuntu Tweak":It's a mystery to me how to get anything to work in Linux.
Um...The bottom line is that Adobe doesnt' make it easy to find the dowload, and you must install any previous version.[...]
Um...
I don't recommend installing Adobe. I haven't used it for about a year (on Win or Linux machines), since I read an article about Adobe vulns being the single biggest cause of computer intrusions. The article said Abode was so hopelessly unsecure (and Adobe so slow to respond to reported problems) that it would never get fixed, blah, blah, blah.
I use Google Docs in my browser(s) and Evince on my Linux desktop(s) -- Foxit Reader on Win machines.
Unless you have a specific *need* for Adobe, I strongly suggest looking elsewhere... 😉
I've also read you have to use a 3rd party utility to fix the button placement for min/max/close in Gnome. Not cool to change a standard GUI option and not provide a way to fix it right out of the box, not to mention forcing said change. It should be optional.
It is optional, no third party tool required, i did it from the command line in about 10 seconds. run this in terminal to switch buttons:
gconftool-2 --set "/apps/metacity/general/button_layout" --type string ":minimize,maximize,close"
I see...I think they are talking about Adobe Flash, not Adobe Reader.
Different strokes...[...]I even like the default theme, but I stand by my assertion that they should have stayed with brown and orange as a default. That color scheme was very unique, and defined Ubuntu as much as the logo did. Whenever I saw those colors together, I immediately thought of Ubuntu, and that's exactly what you want with your product branding.[...]
I upgraded from 9.10 to 10.04 LTS and noticed it became lighter and faster (placebo?)
Things are looking good for now, wonder if I should do a clean install of 10.04. Would be a loyal PITA to set everything up again..
If it's working, it's working. I'd leave well enough alone. I didn't notice a speed increase outside of boot time going from 9.10 to 10.04 on my desktop. On my netbook, the speed increase was tremendous going from 8.04 to 10.04. I think that was mostly due to the EXT4 file system.
I had the opposite happpen. I upgraded a 8.04 to 10.04 and it became so slow it was unusable. I then did a fresh install and had the same problem. I went back to 8.04 for now.
This was a desktop amd xp 3000 with 512 ram. Via video.
Initial reports said it was only possible by using UbuntuTweak, I'm glad there is a way to change it natively. I haven't used it personally. I'll eventually get around to updating it.
