- Mar 4, 2000
- 27,370
- 240
- 106
Corky:
How does the drive perform when loading frequently used apps?
Is your battery life the same or less with the hybrid drive?
For general usage (when the 4GB flash isn't be used), does it fell faster than your Scorpio drive?
I used it on apps today, and it does "learn" from use. First time call of QuattroPro took about 12 seconds. After shut down and reboot, subsequent calls were almost instantaneous.
It does feel faster than the Scorpio Black.
Battery life is not something I care about - I don't even have a battery present when I'm not travelling. I consider battery to be for emergency use only.
It is a good enough feel that I intend to get another for my backup/reserve drive. The Scorpios will then be used for data via the Thinkpad's Ultrabay.
