superman859
I haven't had much luck with PSUs lately...About 1.5 months ago my 500 Watt Enermax power supply (few years old) went out when I was out of town. Not sure what happened. Computer simply wouldn't boot or power up or spin fans or anything.
Yesterday, it's replacement (only 1.5 months old) went out - Corsair TX750w if I remember the model correctly while I wasn't in my room. Again, wouldn't boot or anything.
Today I got some tools and have been trying to figure out what is going on. I think the Corsair overheated somehow since it kind of smells funky, although the case is pretty ventilated (Antec P180) and it's not running much (older stuff, 1 basic dual-monitor graphics card).
First, tried the simple paperclip test - shorted green wire and ground on 24-pin connector, and they both spun up this way.
Next I tried an Antec power supply tester. Plugged in the Corsair, and it didn't even turn on the LCD screen or respond at all. Completely dead. Now it won't even spin up with paperclip method.
The Enermax passed tests by the Antec PSU tester. Voltages were fine, molex was fine, etc. However, it still doesn't power on the machine or even begin to spin fans when actually plugged in.
Also got a multimeter. Didn't bother on the Corsair yet, but the Enermax seems to pass multimeter manual tests as well when not in motherboard. using paperclip for 20-pin (or Antec tester, which also connects the pins), I tested the remainder pins and they all seem to have the correct voltage. I tested the molex, and it too has the correct voltage.
However, if I plug the Enermax into the motherboard and then test the molex, it is way off. 12v comes off as like 140v - 150v, and 5v is kind of jumpy around 0.
Plugging a much older, 250w backup PSU into the motherboard does start it up and CPU fans and everything, although it's much too old and weak to really use as the real PSU.
So I understand that the Corsair is probably dead. It doesn't respond for any tests and smells funky. Overheated somehow.
But I dont understand the Enermax. It passes the Antec tester. It passes paper clip only. It passes manual inspection via multimeter in conjunction with paperclip/Antec tester (unplugged from motherboard), but when plugged into the motherboard (and only the motherboard), it is way off. Is this common for a bad PSU, or is this an indication that my motherboard is evil?
I also don't understand how two decently rated power supplies died, both within a couple months of each other. Is it possible my motherboard is the bringer of death and killing all PSUs that hook in? Or can the other hardware not really harm the PSU (besides asking for too many watts - I need about 375w I believe for everything)?
I bought a new PSU, again, but worry if my motherboard or any other hardware is pure evil that it should be replaced as well.
Any thoughts?
Any thoughts?
