Two cores, two different temps
PTT
20
I have an i3-530, and when running Prime95 (4 worker threads) I noticed that CoreTemp is reporting that core #1 is running roughly 3-6C hotter than core #2.
Is this normal?
PTT
20
Great, thanks. Was thinking maybe I didn't apply the thermal paste evenly enough or something.
aigomorla
21,067
3,575
on idle yes.. because u have background processes which will take up cpu cycle time.
So on a 2 core system, 1 will be doing background processes which will make it slightly hotter.
Load them both up, that is a better way to debug.
The load temps on both cores should be near even.
PTT
20
CoreTemp is reporting right now, when idling, core #1 @ 23C and core #2 @ 30C.
When at full load (Prime95), CoreTemp reports core #1 @ 48C, core #2 at 55C.
Supersonic64
372
Happens to me on my i7. Core #0 is always about 4-5c higher than the other three cores at idle and load.
aigomorla
21,067
3,575
what sink are you using?
this is a sign of a bad mount.
aigomorla
21,067
3,575
Stock heatsink.
What should I do to fix it?
... bah then its fine as it is.
i thought you were using an aftermarket.
Just make sure all the pushpins are indeed secured.
Other then that, its nothing to worry about on a stock air sink.
Supersonic64
372
Stock heatsink.
Nothing, it's totally normal for one core to run a bit hotter than the others. You can try to do whatever you want to try and cool it down but I doubt you will succeed.
It's fine, don't worry about it.
FragKrag
99
I get this too on my i7 860. The rest of my cores are around the same +/- 1C while Core 0 is normally like 3 or 4C above the others :/
