Originally posted by: DougK62
Why don't you have a router already? I always advise people with cable/DSL to get one - even if they only have one computer. It provides security and easy expansion for later.
Originally posted by: RossMAN
Belkin 802.11g wireless router for FREE after rebates.
RossMAN to the rescue once again!! Thanks a lot!
Originally posted by: Elbryn
if your cable company gives you more than 1 ip address just get a cheapo hub/switch. plug cable modem into uplink port and other two wherever. set both to dhcp and you'll be fine
Originally posted by: nakedfrog
ICS really isn't all that bad. My only problem with it was a setting in my firewall that took me far too long to find. Both my PCs are always on, so that's not an issue at all for me.
Originally posted by: clamum
IIRC you can put two NICs in your home computer and run the cable modem to one, and connect your home and laptop with the other one.
you mean run one ethernet cable from cable modem to onboard lan in desktop. and have another cable run from secondary (PCI slot) NIC to onbord lan of desktop??
will that even work?
You're welcome.
Do yourself a huve favor and just buy a damn wifi router = problem fixed![]()
You're welcome.
i agree with everyone who's mentioned getting a router. it's so cheap and you get the added benefit of a hardware firewall. in the future you can network many more, easily. plus, you have wifi!
