TV Tuner
ryan954
32
I have been searching for months for a suitable TV tuner card for my pc. I need a card that will work with DirecTV. I also am looking for a card that will change the channels on my receiver. DirecTV works like this: You go to channel 3 and all the DirecTV channels run through channel 3. This is why I need a card that will change the channels on the satellite receiver and not on just the card. Thus, I will hook the receiver up to the card and then scedule recordings, which the card will then change to the appropriate channel at the appropriate time. Any suggestions?
Please email me at ryan954@hotmail.com
pulse8
20,860
I don't think the card you're looking for exists. I haven't seen one that will control a cable box let alone a DirecTV receiver.
thedarkwolf
9,037
132
The cards won't but you can use a transmitter and some software that will controll your DirectTV receiver. Look around on AVSforum in the HTPC section for somthing called an IRblaster(I think thats what is called).
