JEDIYoda
- Jul 13, 2005
- 33,986
- 3,321
- 126
Originally posted by: chizow
Originally posted by: JEDIYoda
Okay I have been through this with a good friend of mine on these forums.
Up to a point there is a hard and fast technical reason including how many heat pipes...the alloy used......the density of the heat sink....how far apart the fins are from each other...etc....
With that said.....
There are heat sinks from a few years ago that are still very good heat sinks. Even with the advent of the Zalman 9500 and 9700 as well as the larger Tuniq and the Ninja and the new CoolerMaster heat sinks.
Such heat sinks would include the Thermaltake XP90 copper....the older Ar tic Cooling heat sinks....and so on and so on.
Yet you also such name brand companies as ASUS that has some monstrous heat sinks yet when stacked up against the big boys such as Zalman...Scythe...Thermaltake and ThermalRight they are a distant 2ND.....as well as some other brand...
The one surprising brand in my opinion has been the Arctic Cooling series.
They are always affordable yet they offer performance that is comparable to what I would call the big boys of the heat sink world!!
Now the kicker is.....the differences are very very minuscule and a lot of times these other brands as in the Arctic Cooling Series are with 1c-3c of the big boys.
Is there a best of the best?
That's a loaded question because what works in a given system depends on proper airflow throughout the system as well as the heat produced by various components.....then you need to take into account how many components a system has...
We all know that 2 video cards produce more heat than 1....and we all know that 4 hard drives produce more heat than 1 would.
Then we take into account The ambient temperature of the room you are in...etc
There is no hard and fats way to give state with certainty such and such heat sink is the best!!!
That's why I would not switch from a top heat sink say i was using the Thermaltake Typhoon...the improvement in temperature of say 1c-3c even though in degrees Fahrenheit its quite a bit still is not IMO worth it!!
I for one think the heat sink market is one of the few where if you like something because it looks cool well then get it...it will definitely work adequately for you. In the heat sink world BLING works and does not diminish the quality!
Now if you are after super low temps then you will be purchasing more than one heat sink and chasing the golden dream.....but that's alright also!!
Have fun!!![]()
Summary: Different heat sinks have different levels of performance based on design, engineering, and materials used. Over time, certain heat sinks rise above their competition because of the above mentioned attributes. But there's no reason to expect any different performance between them because they're all just expensive heatsinks11onee111!!!!one!
Its funny that you don't see the irony of your comments.
Thanks for the additional links Corsa, I'm sure that guy was just a noobie that didn't think to test them using the same test bed or clean his old HSF though.![]()
First what Irony??? There is no irony...there is no absolute best heatsink for a given system or your reading comprehension is not very good!!
Your summary was not accurate at all. I did not say nor did I imply that --Over time, certain heat sinks rise above their competition because of the above mentioned attributes. But there's no reason to expect any different performance between them because they're all just expensive heatsinks!!
The truth of the matter if for each and every system what works well in your system might not work well in my system!!
I remember when people decided to convert to the Scythe Ninja because in the reviews at the time it was considered the best heat sink bar none!!
Well there are many many posts from people who bought that heat sink and saw NO difference in temperatures from the aftermarket heat sink they were using and others only saw a 1c or 2 c difference.
Why?
Because from system to system its a different beast and there are different variables!
Sure go by the reviews you read on given heat sinks. That what those reviews are for. To be used as a guide. But reviews and practical hands on experience as has been proven in these and other forms time and again are two different animals!
I would rather have somebody post hands on experience any day over a review!!
Its ironic that you cannot grasp this simple rudimentary concept!
http://www.tweaknews.net/reviews/zalmancnps9700/index4.php -- results
http://www.tweaknews.net/reviews/zalmancnps9700/index5.php
http://www.pro-clockers.com/reviews.php?id=192&page=4 -- see below
Here is a good example of what I am saying about 1c-3c differences in TOP heatsinks...
Cooler -------------------------- Idle Load
Intel Stock -------------------- 35---51
Scythe Andy Samurai Master- 33---46
Scythe Infinity----------------- 32---43
Zalman CNPS9700 (Low) ---- 33---45
Zalman CNPS9700 (High) ---- 32---43
Thermalright Ultra-120 ------- 33---44
(notice the 1c-3c difference even among these heatsink)(note if you look hard enough you can find sites that have heatsink wars from the past)Tests conclude that on the highest setting the CNPS9700 is one of the best coolers that we have tested here at Pro-Clockers. It even draws with the Scythe Infinity, the current king of the hill here at PC. This may not surprise a lot of people as the CNPS9500 performed pretty well itself when we tested it.
Conclusion
The conclusion to this article is that the Zalman CNPS9700 is one great cooler. It performed right up there with the best in the market. the added size definitely makes the 9700 a contender and not a pretender. The installation of the cooler is a little bit improved with the newest mounting system from Zalman. Moving and replacing the 9700 is pretty painless.
One thing that a lot of us would not like about the 9700 is the pricing. The cooler will set you back about $75. At a lower price there are other coolers that perform relatively equally as well. Even the little brother, CNPS9500 is something to think about when looking at Zalman cooler, if you want their superb quality.
So, I am awarding the Zalman CNPS9700 the ?Highly Recommended? award.
I am not here to argue what I am saying about heatsinks!
What I am saying is true yet what really needs to be understood is its truly a buyers market! You can hardly go wrong with any aftermarket heat sink that you decide to purchase!
Thats why I threw the Arctic Cooling series into my example.....They are very good and quiet(if your into quiet) and fairly priced!!
Now water thats a whole different story; when done right will yield spendid results!!
Good Luck!!
