Trying to upgrade my system...
zorasson3
Stock is as follows
AMD Athlon 2200xp at 1.80 ghz on 133x13.5
Nvidia Geforce 4 ti4200 4x at 250/500
pc2700 only running at 133
ran a custom game-only run of 3dmark03 and got a score of 1460, since then i overclocked
from a 1.8 to a 1.92 on 167x11.5
and clocked my force to
260/555 (i swear i did it 5mhz at a time till it crashed, then decreased by 1mhz till it ran smooth without white noise)
doing so accomplished a rating on the test engine of 1602
I'm just curious, is this a good gain for the changes I made? and what additional changes can i/should I make?
Um, the changes you made yielded typical increases in 3DMark03.
IIRC tho, the 2200+ doesn't run @ 1.8GHz stock.
Are you talking about changes to your existing system to improve performance or changes to upgrade your system cost effectively?
Originally posted by: zorasson3
Stock is as follows
i dont think it worth the time to OC these old part and squeez some framrate out of this.
you should upgrade your video card to DX9 compatible card if u want to play some newer game
Stock is as follows
Wow...I had the exact same setup as you !!! Yep thats a nice gain...
