bluesky787
Hi,
As I said, just trying to build my first system from scratch in order to get
a decent PC for gaming yet save on cost as much as possible at the same time.
Any ideas/advice would be greatly appreciated especially if you spot any
incompatibilities or RED flags....
Thanks again..
Ideal system:
Processor/CPU : Intel Pentium 4 550 3.40GHz 800MHz 1MB Socket 775 CPU $73.00 USD
CPU LINK
Graphics : BFG GeForce 7900 GS OC / 256MB GDDR3 / SLI / PCI Express $135
Motherboard: EVGA nForce 680i SE SLI (TR Version) NVIDIA Socket 775 ATX $150
Memory : Corsair Dual Channel TWINX 2048MB PC6400 DDR2 800MHz $99
Hard Drive: Seagate / 320GB / 7200 / 16MB / SATA-300 - $65
QUESTION will SATA-300 work on my MOBO??
DVD : Lite-On Super-Multi LH20A1H Lightscribe DVD Burner - $40
CASE : Ultra UV Wizard Blue ATX Mid-Tower Case with UV - $20
Case Link
CPU fan : Masscool 8W501B1M3G / Socket 775 / Intel Prescott / Copper Core / CPU - $20
Power : Ultra /X-Finity / 600-Watt / ATX / Dual 80mm Fan / SATA-Ready / SLI Ready - $40
Total is $642.00
Am I missing something? I went through this many times, this is all the parts need to build a full PC from scratch right? So can this all work out? I'd be very happy if I could get a decent system like this for under 650 bucks... I know I'm a bit conservative on the Ram and also HD and also probably the video card itself, but they are all decent and later I will upgrade them... If anyone knows of a better, more modular and 'future proof' aka expandable and upgradable MOBO that I could use to stay up-to-date in the future without purchasing a new PC, please let me know....
My only concern is the SATA-300 HD compatible with my Mobo? Is the CPU going to work with the Mobo? Is the 500 watt power supply going to be enought? Thanks
Thanks again..
Ideal system:
CPU LINK
Case Link
Total is $642.00
