Trying 2405FPW via VGA @1920X1200 and comparing it to DVI? Can someone try?
Peter
9,640
The difference is that on DVI, the signal either gets there and is inherently loss free, or it doesn't. There are no inbetweens. With a poorly implemented DVI output, you're either limited in maximum signal frequency, or higher resolution modes just plain don't work at all. But if you do get a picture, it's perfect.
MAME
Banned
Sep 19, 2003
9,281
Originally posted by: MercenaryForHire
Look for a "reduced DVI signalling" or "Alternative DVI signal" checkbox. You'll have to run a reduced blanking interval but you should be able to run 1920x1200 over DVI.
- M4H
does reduced dvi signalling effect the image quality?
MAME
Banned
Sep 19, 2003
9,281
- M4H
MAME
Banned
Sep 19, 2003
9,281
- M4H
