- Sep 9, 2004
- 192
- 5
- 81
I ran a Radeon R9 280 video card for a few years in my PC. No problems. I decided to upgrade my wife's video card and bought her a 5700XT. I took her old RX590 and figured it would be a small step up for me. So all same PC, just swapped in the RX590.
It's crashing under load. The entire PC reboots. I even pegged the fan curve at 100% at all temps (and I heard the fans ramp way up), but it still crashes the entire computer within about 1 minute of playing a game. I can websurf all day.
Well my power supply doesn't have an 8-pin video card connection. I bought an adapter that allows the connection of two 6-pin PCI-E power connections into one 8-pin that would then go to the card. So in theory, I'd have power capacity of 225W, no? 75W from the PCI-E slot itself, then 75W from each 6-pin PCI-E plug? This should be sufficient, no? If no.... then WTF do they even make the adapter?! Let alone all the versions I past up with only one 6-pin input!
As a heads up, I tried one version of driver backward. Same issues. Also keep in mind this card worked great in her computer for over a year.
