- Jan 21, 2002
- 3,701
- 0
- 86
I received my Radeon 9700 Pro today. I took out my Ti500 and deleted the nVidia drivers from the Control Panel...then shut down and stuck the 9700 Pro in the AGP slot.
Now what happens is, WinXP will boot to the desktop but I cannot install the card! It doesn't get recognized as a "Display Device", it gets recognized as "Other Hardware" and has the yellow exclamation point. What also funny (to me) is that it gets recognized twice for some reason; there is always a double entry for the card.
Anyway, I skipped the "New Hardware Found" wizard and was going to try to install the Catalyst drivers. The installation starts, but then I get an error that installation could not be finished and that I need to set my card as a Standard VGA display adapter. But I can't do that because the card isn't showing up as a standard display adapter! Everytime I delete it from "Other Hardware" in Device Manager, it shows right back up after the next bootup.
Anyone else had this problem? I have a Soyo Dragon KT266 board BTW. Asus P4PE is on the way, but I figured I'd try the Radeon out on this board first. It should work, right?
