Originally posted by: NeoPTLD
Can you replicate this by attaching an atomic clock on a large rotor and spinning it fast enough to achieve a linear velocity equivalent to Concorde? I don't know if this is possible realistically, so I mean in theory.
Any movement should work. If you could attach a massless clock to a photon, and then read it a billion years later, the clock wouldn't have changed at all.
Movement through spacetime, that is our 3 every-day sized spacial dimensions and one time dimension, can be thought of as a clock having a certain allowance of "speed". It can move with all of its speed through time, and none through space (it's resting). That clock is going though time as fast as possible. It can move with a little of its "speed" through space, and a lot though time, like the clock on that plane. It's moving a bit slower through time, so it says 4:38 pm while a clock on the ground would say 4:39 (Note that it would have to move pretty fast to have a 1 minute difference over a 12 hour flight, but you get the point).
The clock could move with almost all of its "speed" through space, and therefore it would have very little of its allowance to spend on movement through time. Something moving .9999999c is an example.
A massless clock can move with all of its "speed" through space, and therefore never age. A photon never ages. You can't really ask what it would be like, any more than you can ask what going 15 miles south of the South pole is like. You just can't do it.
