Originally posted by: NissanGurl
Originally posted by: alkohoLiK
So aside from the desk snapping in half. How do you guys like the way it came out?
I like it. If either the manufacturer or OM replaces the broken piece you might consider purchasing a mounting kit for the monitor and finding some studs near that corner instead of putting it back on the desk. If you can find one with a swing arm that supports that size it would probably have the same look without the risk of collapsing the desk. Just a thought.
Good idea - you're in a corner too, plenty of studs to bolt the arm into....
Looks good otherwise! :thumbsup:
