It's very puzzling why AMD wouldn't just produce a demo to demonstrate the tech. Do they want to invite speculation/FUD?
Not sure why we bother trying to explain this. They aren't interested in the tech. They are just here to talk bad about amd.The scope of the first demos was to show that the technology is working with current hardware. It was not meant to be a demo of the final product capabilities.
Your crappy monitor refresh rate cannot synchronize with your GPU fps output. Their Demo DID and that is evidence Freesync is working using current technology and hardware.
Granted they only did that at a steady fps rate, but the technology is working.
They also have said that more prototypes will be available in September so lets just wait and see what those prototypes can do.
And the first demo did not show that the technology is working with current hardware. Not in any regard. That's the problem.
They claimed it showed the tech is working, to the point where you believe that's what the demo showed. Only, the demo didn't show that, at all.
You're right, my crappy monitor can't do that. Here's the thing: neither did their demo. Their demo DID NOT. They claimed it did, but it didn't show that. What it did show is that they were running a fixed fps, and that if you match your fixed display refresh rate to that fixed fps the video looks better. True, it looks better, but it's also not synchronized variable refresh, which is what G-Sync does and what they claimed the demo was doing.
We're bothering to explain it because you still don't understand that they didn't show what they claimed to show, and instead showed something completely different and not at all related to what they were claiming to show.
It's not "talking bad about AMD" if what AMD did is actually legitimately bad. That's called a truthful discussion.
Either you are trolling or you dont understand what synchronizing the Monitor Refresh Rate (Hz) to GPUs fps output is.
As i have said, they DID synchronized the Monitor refresh rate to a steady fps rate of 50fps. That was made using current technology and hardware(Toshiba Satellite Click notebooks).
The faster you will understand this the better for you and the rest of the forum.
And why does any of this matter? Why should I care that they synchronized at a steady 50FPS with current hardware?
Why do I care that they did it with current hardware?
Obviously they need to release new hardware for Free-Sync, so why demo on limited current hardware?
They showed part of the technology is working, but not the part that people care about.
We care that it is working on current hardware because that means we dont need extra hardware for the technology to work, elevating the cost of the monitor to higher prices.
I've been explaining this to him since the video released. He doesn't get it. He claims they set 50hz v-sync on the monitor on the right. If they did that it would look like the monitor on the on the left where the frame time (number next to fps in parentheses) is static @ 33.3Xms. It only changes from 33.34ms to 33.36ms and very slowly. That frame time number for all intents and purposes being static = v-sync. The monitor on the right is rendering at 49.XX fps, but the frame time number is fluctuating constantly @ 20.XXms. The only issue with this demo is that it's too simple. The rendering isn't complex enough to show large swings in FPS and is also true on the second demo. This was confirmed by the media when discussing the second demo with AMD.
If that is the case, why didn't they show us variable FPS in their demos?
Im not AMD representative to answer why they only show that or the other, give me a break.
We have the demos, we can see what they have and we wait for more, simple as that.![]()
"This technology" exists since 2009 and it's called PSR.
G-Sync on the other hand is the only form of adaptive-sync which has been proved to be working.
It's very simple: If "this technology" would have existed before G-Sync you could show us a video of it. Otherwise all the claims about Freesync are simple based on G-Sync...
Haha, you did well. Next question, who shot JFK?
But really, since your posts are just your opinion, why do you think they haven't demoed variable FPS yet?
Hopefully with the samples we'll see something genuine and some details about how it works,
NEWARK, CA (12 May 2014) The Video Electronics Standards Association (VESA®) today announced the addition of Adaptive-Sync to its popular DisplayPort 1.2a video interface standard.
Computer monitors normally refresh their displays at a fixed frame rate. In gaming applications, a computer's CPU or GPU output frame rate will vary according to the rendering complexity of the image. If a display's refresh rate and a computer's render rate are not synchronized, visual artifactstearing or stutteringcan be seen by the user. DisplayPort Adaptive-Sync enables the display to dynamically match a GPU's rendering rate, on a frame-by-frame basis, to produce a smoother, low latency, gaming experience.
