[TPU]Crysis 3 PC System Requirements Detailed
Jaydip
3,691
21
http://www.techpowerup.com/176516/Crysis-3-PC-System-Requirements-Detailed.html
Minimum
Windows Vista, Windows 7 or Windows 8
DirectX 11 graphics card with 1 GB Video RAM
Dual core CPU
2 GB Memory (3 GB on Vista)
Example 1 (Nvidia/Intel):
o Nvidia GTS 450
o Intel Core2 Duo 2.4 GHz (E6600)
Example 2 (AMD):
o AMD Radeon HD5770
o AMD Athlon64 X2 2.7 GHz (5200+)
Recommended
Quad core CPU
4 GB Memory
o Nvidia GTX 560
o Intel Core i3-530
Example 2 (AMD):
o AMD Radeon HD 5870
o AMD Phenom II X2 565
Hi-Performance
Latest DirectX 11 graphics card
Latest quad core CPU
8 GB Memory
o NVidia GTX 680
o Intel Core i7-2600K
Example 2 (AMD):
o AMD Radeon HD 7970
o AMD Bulldozer FX4150
brandon888
537
well .. it looks realistic .... sure more demanding then Crysis 2 but not that much .... hope will run it on high settings with my EVGA GTX 560 TI 448 cores 797 mhz ^_^
Thnx for info dude
DrBoss
415
Seems reasonable...
I still have my doubts about how "open" the level design will be in Crysis 3. Crysis 2 level design = fail.
0___________0
284
In the recommended specs for the GPU it has a GTX 560 vs. a 5870, the 560 is definitely slower than the 5870. GTS 450 is generally slightly slower than the 5770 as well, except for the games that favor nVidia. Do they expect the game to perform better on nVidia hardware?
EDIT: I went back and looked at the thread with the benchmarks and the specs seem about right.
brandon888
537
Seems reasonable...
there is some gameplays on youtube ... seems like it's more open then crysis 2 but not as Crysis 1
tviceman
6,734
514
www.facebook.com
Seems reasonable...
Once Crysis 2 got it's DX11 patch and HD textures, it looked great. Everything else about it was pretty much fail though (IMO). The story was an awful mess of eye rolling crap, the level design was awful, the aliens were worse than Crysis 1 and Warhead, the boss battles were idiotic. And the ending - God awful - perfectly fit in with how insanely dumb the game was.
0___________0
284
2600K or FX4150?
Yeah, the FX-4100 isn't even close to the i7. But look at the Phenom II X2 550, averages just 24 fps, the Athlon II X4 620 thrashes it, I wonder if that's accurate, seems too low. They use a Phenom II X2 for the recommended. Seems like the recommended for AMD should be a Phenom II X4 or quad FX and the hi performance should be an 8xxx.
DrBoss
415
Yea, not to mention the SUPER WEAK tie in to the original story. I wanted to go back to the island and finish what was started in Crysis 1/Warhead. Instead, i fast-forwarded an unknown amount of time and was thrown into an entirely new world/story.
Oh yea, and it was a console game.
SPBHM
5,065
418
4150=8150?
also quad core, example Phneom II X2?
this game must be unplayable on a Athlon 64 X2...
in low res/settings, I'm quite sure something like a 5570 can run the game at around 30fps.
Spjut
931
160
Seeing that it's coming for the 360/PS3 as well, the minimums are very high.I really hope there's a big difference between the console versions and the PC versions at low. Can't see why it doesn't support DX10/10.1.
videogames101
6,783
27
Sigh, Crysis 1...
You could have SLI'd 7800GTXs and it would still chop on maximum settings...
Spaceme1117
19
I'm betting Crysis 3 will need GTX690's in SLI for max settings and smooth gameplay.
I remember Crysis 1 and that my two GTX8800's in SLI (which was top of the line at the time) would be brought down to their knees with max settings.
