Question TP-Link TL-SX105 *fanless* consumer 5-port 10GbE/multi-gig switch (IN STOCK @ Amazon, $329)
VirtualLarry
56,587
10,227
Finally the bigger consumer brands, are giving us 10G/multi-gig devices, fanless, at reasonable cost.
Edit: Anyone currently looking at the above, that would prefer a managed switch with almost as many ports, for a similar price, check this one out:
Fallen Kell
560
Still pricing is insane. That is a dumb unmanaged layer 2 switch, and they want $330-350 for it. I get that is "cheaper" than others for 10gigabit capable NBase-T ports, but that is still $70 a port for unmanaged ports.
If I was going to spend that much money, I would much rather pickup a used/refurb Brocade ICX6450 off ebay for around $150 and buy 4xSFP+ NGbase-T transceivers for another $200 (that is assuming I need the ports to all be RJ45 ports, and don't have or can't buy SFP+ based network card for one or more systems and use cheap twinax cables to connect to it, saving the cost of needing the transceiver and probably another $30-50 on the network card). For approx the same cost, I would have a layer 4 managed switch, with 48x1gb ports, and 4x10gb capable ports, with support for VLANs, ACLs, and port aggregation/bonding. Sure, I give up 1 10gigabit port, but at least with this switch you can setup proper network segregation for a guest VLAN, or one for IoT devices.
Reactions: ch33zw1z
Ranulf
2,921
2,602
Nice to see but meh. 2.5G or go with a solution like Fallen Kell's suggestion.
aigomorla
21,134
3,669
NO that switch looks no where near capable of fanless with it being sealed.
Larry you and i both have first hand experience with the mikrotik one, and you know how HOT that thing runs.
Its not just mikrotik, its every other 10GBe switch including the ASUS one that runs hotter then hell.
The only passive 10gbe switch i will trust without a fan is the mikrotik crs308, but that doesn't have RJ-45 ports and instead SFP+ which even draws less power to help it stay cool.
VirtualLarry
56,587
10,227
Well... hmm. Now I want to try one out.
It's not that I don't want to defer to your extensive experience, I do.
But by the same token, this is a new product, with 10G/multi-gig, and probably uses a chipset with smaller lithography, so it likely runs cooler.
Or maybe, it is an inferior design, since 10G-baseT does take more power to run over the cables than 2.5Gbase-T, and maybe their engineers were lazy, and re-used their 2.5GbE-T design for the chassis, figuring that it was a drop-in, and most importantly, that an ordinary consumer WOULD NOT have all of the ports blasting away at full line-speed. But it does claim to support that level of switching capacity, so IDK.
VirtualLarry
56,587
10,227
Do you think, in light of consumer 10Gbe/multi-gig switches, that the 2.5 gbe switch crowd completely missed the boat on making them "affordable", and thus triggering a 2.5 gbe "upgrade wave" among consumers, and that, given a choice between an expensive 2.5gbe switch, and a slightly more expensive 10gbe/multi, most consumers would only want to upgrade and deploy once, so eventually, 10gbe/multi for consumer switches will reach volume, and thus lower prices than the 2.5gbe switches.
Ranulf
2,921
2,602
They've been saying we're right around the corner to mass availability and affordability for 5+ years now. That Trendnet 8port is $175. Toss in $25 2.5gb cards and you've got 4 systems at 2.5gb for the price of the 10gb 5 port switch.
If you need 10gb that bad, you should probably look at the other options out there and then use converters if you need to swap to rj45 jacks.
KentState
8,397
393
When I heard about this earlier this summer I was excited for a "cheap" desktop 10Gbe switch, but at > $300 I have no interest. I will have to stick with the two 10Gb switched I have in the basement where the fan noise doesn't matter.
fkoehler
225
198
Fallen Kell keeps bring up the Brocade, however its too big for my needs. However since its a Tier 1 manf., I thought I'd see what I could find on eBay.
While this won't give you more than 2 10G ports, its a smaller 1U size, and surprisingly Amazon came up listing this for even less:
Funny, pricing on the normal used market for this L3 switch w/2x10g module is $7K.
I'm seriously thinking of dumping my Cisco, again....
