Googer
- Nov 11, 2004
- 12,576
- 7
- 81
Originally posted by: Fritzo
BTW- If people are worried about HDMI cable prices, Taget sells GE brand HDMI cables for $30-$45 (depending on length).
Originally posted by: videopho
...and since then I have gone to a 3rd different dvi cable, the latest from Monoprice, a very well constructed 24awg gauge size that proves worthy, it offers better/sharper pictue quality than any other previous ones. BTW, none of my dvi cables are longer than 3 ft and cost more than $15.00. I also use the Zektor switcher for all of my dvi switching ie.
:QI have a collection of well over 1,850 DVD's
I ordered an OPPO OPDV971H a couple days ago. it'll be here today
Originally posted by: StormRider
Has anybody done any comparisons between these upconverting DVD players and HD DVD players? I'm hoping that these upconverting DVD players produce output close enough to true HD DVDs so that most people would have trouble telling them apart. I've already invested a lot in my DVD collection (I have over 500 DVDs) and it just pains me to think about upgrading them to HD DVDs...
Originally posted by: ironk
i think if you want the closest to the best picture quality with upconversion under $150, get the oppo. I tink $60-70 more is well spent to gain picture quality. Otherwise, go with the panny if your budget is tight...i doubt the panny will give you the same quality, but maybe you'll be satisfied.
Let us know how it turns out.
This might help a little...
Comparison of 'FOTR' dvd & hd screenshots
Being amazed at how fantastic the HD transfer of Fellowship of the Ring looked, I decided to compare it to the transfer on the DVD. Now, the DVD transfer is among the best you can find on DVD, so this really is comparing the respective creams of the crops.
I used WinDVD 6 to capture files from the DVD, and Elecard Mpeg2 player to capture from the HD stream. Both were captured directly to BMP files and converted to JPG at very high quality so there should be almost no artifacting introduced (sorry, the BMP files were too large to use).
I used Photoshop to bicubically resample the DVD source images from 852x480 to match the 1920x1080 of the HD images. This page features the HD image sampled down to the DVD's resolution of 852x480. Surprisingly, even at DVD-resolution the HD source features more detail.
Now, I know that this isn't the same as seeing them in the dvd players. And the upscaling for use as a comparison is questionable.
But, look at the hd shots that were scaled down to dvd resolution. Those tell me that there will be a noticeable difference (if you have a large-enough hdtv) on the hd discs. But, not all movies will really 'need' that difference (i.e. it'll be worth it for eye-candy movies, but maybe not 'Anchorman').
Those pictures are very dramatic, but depending on your display, the final result might not be as big a difference. It is hard to compare screen captures directly from files with real-world results. That being said, it was very impressive.
Actually yeah...i know that the chipset changes everything, however, you just gotta go with oppo. They have proven to be pretty darn good with upconverting....why do you assume this? This just came out and there is little first hand experience of this unit. Is it just because the last Oppo was pretty decent? But this new one has a different chipset, which changes EVERYTHING.
Originally posted by: MOCKBA1
Just want to add that DV-970HD is $50 cheaper, and what is more important it has descrete on/off remote codes. So go for this player and do not look further.
