Question Toshiba MG07 14TB not detected at power up but fine at reboot
youpii42
Hello
I tried adding a Toshiba MG07 14TB (MG07ACA14TE) to my home linux server (Intel i3-8100+Asrock Z390M-mITX/AC+BIOS 4.30) and it's not detected by the bios at powerup.
In Centos 8.4, it's not listed by lsblk even when using the rescan-scsi-bus.sh script.
But all is fine (in the bios and in centos) with a soft reboot.
I suspect some kind of timeout during the powerup phase but Fastboot is already disabled in the Bios.
Anything else I can do ?
17,167
youpii42
Again from that PDF:
Maybe the PSU is providing less than 4.7V upon PC hard boot? What is your PSU brand/model?
PSU is Seasonic G360 (SSR-360GP) 80 plus Gold
Bios readings seem fine
  • 12V : 12.196V
  • 5V: 5.086V
  • 3.3V: 3.456V
I also tried with all the other HDDs unplugged with the same result: Toshiba MG07 14TB (MG07ACA14TE) not detected at power up but fine after a soft reset.
I tried swapping PSU with a larger Seasonic Prime Ultra 850 Titanium (SSR-850TR) and it still was the same.
Last test was to use both PSUs:
Prime850 for Mainboard only
G360 for the Toshiba HDD only
G360&HDD was powered on a few seconds before the Prime850&Mainboard
With that combo, power sequence was fine, with the HDD detected in linux.
So I guess the MB boots too fast for the HDD to be properly detected during the power on sequence :(
youpii42
just a dumb question but is it set @ 4k or 512e?
MG07ACA14TE is 512e. Why would it matter for BIOS detection ?
Soulkeeper
6,731
155
Try playing with you bios settings.
Disable "quick post" or similar. Some bios have a delay in seconds you can set.
If you are still unable to fix the issue i'd suggest contacting customer support for your motherboard and/or toshiba.
Does you bios have a boot override list ? is it detected inside the bios with that ?
Soulkeeper
6,731
155
I just noticed asrock has a beta bios which seems to address this issue:
VersionDateSizeUpdate BIOS Under
/ How to Update
DescriptionDownload
[TD][Beta] 4.30G[/TD]
[TD]2021/9/13[/TD]
[TD]8.58MB[/TD]
[TD]Instant FlashHow to Update icon[/TD]
[TD]
Optimize specific high-capacity HDD.​
[/TD]
[TD]Global Download Global[/TD]
[TD]China Download China[/TD]​
