> In case this is what you're asking about, I have tried setting the display to 800x600, and with "Panel Fit" enabled, the 800x600 display fills the full LCD area. With Panel Fit disabled, it shrinks the display down to the middle part of the LCD, with black border all around.
> Is that what you mean by "stretch"?
Okay, so "stretch to fill" is aka "Panel Fit".. That's the first part.. Whether or not it would stretch 640x480 and 800x600 to fill 1024x768 or leave black border.
> If so, it worked nicely, although at 800x600, letters were little 'fuzzy', but not "blocky". But, XP also has Cleartype, which might've cleaned it up a bit.
This is the second part...
It's important that everything (not just letters, but they are the main indicator) is SMOOTH (slightly soft/fuzzy) versus blocky.
Older notebooks (not too long ago in fact) simply took a small screen, and doubled the width of every other pixel.
This resulted in a Letter H having a double wide left bar, and a single wide right vertical bar..in other words, looked like crap!
The newer ones "dither" it to place a color between the original pixel and the next pixel to "blend" it. Thats why text looks fuzzy.
If you turn off ClearType (I actually don't like clear type for MOST things), does it still look good, or is it only cleartype (and not the chip in the panel) doing the adjusting? The easiest way to tell is go to a site that has text EMBEDDED in a bitmap (versus standalone). Cleartype can't affect it, so you'll know if it's automatic (hardware) or windows doing it.
Best place to look for that?
http://mail.yahoo.com
Look at the small text to the right of the globe and the 2 girls in the air-charis... That test is in the picture.
Does it smooth it or is it really blocky and unreadable if you go to 640 or 800 setting?
Also... another clue is the softness of the bios boot text that splashes on the screen before you get the Windows xp startup logo. If soft, it's stretching the 640 to full screen nicely, if blocky, then bad.
Thanks! Please repond quickly...Trying to decide on this sucker
