flexy
- Sep 28, 2001
- 8,464
- 155
- 106
10% hardware, 90% software/setup
Common mistakes:
Problems with too old hardware (eg. drives not dma capable, hangs while setup...happened to me)
Messing around/installing CPU or heatsink....(with a screwdriver....too much thermal paste....scratched motherboard etc...)
Putting in Ram sticks the wrong direction (yeah...that really happened to one..i remember this thread a while ago....amazing if you consider the ram sticks usually have a notch and only fit one way
Forgetting to connect fans to the PSU/MoBo connectors..therefore blowing a cpu
Stuck PSU and/or HD/Floppy drive connectors......(literally ripping the cable off the plug while the plug is stuck in the drive )
Jumpers (in general...they're always good for some fun
Btw..."installing RAM while motherboard is in the case"
I do that all the time (and i will do again today, i got a RMA back from curcial)....do you seriously expect removing the whole board because i want to add/exchange a new ram stick ? I hate that too...especially since the board usually always bends down a bit and there is no way of pushing against it from the other side...
I just wish it would be common that there are like additional stands BELOW the ram connectors (in the middle) on the back of the board just to avoid that "bending"...but obviously no mobo manufacturer ever came to that idea :/
Edit:
A few years ago i got that 486 board with a DX40 cpu... took it out (better: my roommate
)...looked at it...put it back..wanted to try out the new purchase.
Board didnt fire up...no bios...no nothing.....
Called the one guy you sold me the board....met him...went to a computer repair center to let the board check out whether it worked fine.
Turns out the CPU was put in the wrong way
Put it in the right way..board fired up...everything was fine....sometimes *really* stupid things can happen
Common mistakes:
Edit:
