Top 25 passwords
alkemyst
83,769
19
But trustno1 is a phrase. Those are supposed to be unbreakable!
Not sure if sarcastic or not...immune from dictionary attacks but not brute force. 8 character passwords aren't extremely difficult for bot nets to attack.
JujuFish
11,457
1,058
The sarcasm was palpable in that post, and trustno1 is not immune to dictionary attacks, since any password dictionary that doesn't have the most common passwords would be pretty pathetic.
alkemyst
83,769
19
popular 3-5 character passwords are no longer common as many have gone to at least a min. of 6 and usually 8 characters. My passwords for secure sites are usually phrases of none dictionary words and 15 characters or more.
JoeyP
386
I would have thought leet would have been in at least one of those. Like P@55w0rd
sourceninja
8,805
65
I use lastpass and most of my passwords are unknown to me and at least 32 characters (or the limit for a site if the limit is lower).
My lastpass password is pretty complicated phrase of words, numbers, mixed character types and multiple languages.
I think pass phrases are better than passwords. It's hard to guess, easier to remember, and has higher entropy.
Look at the password "Ippon and Yuko are Judo scores." which seems very simple until you think of what would be required to brute force it. You would need to know the number of words in the phrase, the languages used in the phrase (2 here), the use of capitalization (or not), if it contains punctuation, etc. Remembering this is easy. I like judo and those are two kinds of points you can score in a match.
Pardus
8,197
21
I use Dichlorodiphenyltrichloroethane - no one can spell it , most don't even know what it is
JoeyP
386
Someone ought to invent a keystroke capture device that fits on your keyboard. When prompted to enter your password, press your finger on its biometrics reader to have it capture, enter the password, and then press the same finger to store it.
Especially at work, where you may have different accounts not using LDAP, this could authenticate for you. You'll just have to remember which finger is linked to which password. You can always knuckle in the password anyway.
sourceninja
8,805
65
You could also get your company to setup a identity vault and just sync all your accounts. (I'm in the middle of a project doing just that now).
