Too much for this power supply?
MrBossman
38
I was looking at getting this OCZ Power Supply but I need to know if it will be enough to handle the load I'm planning to use it on. I'm leaning towards the idea I need a 500w supply but I know the specs on the rails for the OCZ would probably cover it. I just need to know for sure.
Here's the specs of what I will be running:
ASUS K8V SE Deluxe Motherboard
3200+ AMD64 cpu
1 GB Patriot Extreme (Low Latency) PC3200
Geforce 6800 128MB Vid Card
2 Optical Drives: DVD Burner & DVD-ROM
At least 3 Maxtor IDE HDD: 2-160GBs and a 200GB, 8mb cache & 7200RPM
Finally some minor cooling at this time. Will look at upgrading later.
All of this is what I will run at the time of getting the power supply, but I will plan to upgrade later. Who knows? Maybe a SATA drive or 2, better cooling, better vid, etc. Will this power supply handle that current load and, within reason, handle some additional upgrades or do I need to go larger? I've got a budget of about $100 which I know is not a lot, but I was thinking of a 500w Ultra then this option came up.
-Bossman
LiLithTecH
3,105
That should be more than adequate for your needs, current and future.
That OCZ is rock solid, but not very quiet (if that is a concern).
The true measure of a PSU is not how big it is, but rather its ability to sustain
a constant voltage under adverse conditions (low input voltage, high input voltage, less than perfect devices, etc..)
Specifically, the combined +3/+5 voltage is 230W max, more than adequate to cover the
GPU - CPU combo you have. (CPU = 75W, GPU = 75-100Wmax)
