Originally posted by: n7
*bangs head*
High temps are pretty normal with C2Ds as they're being measured via a digital sensor.
It's unlikely you'll be able to run under 60C Orthos load overclocked unless you're on some form of water or better.
You wouldn't want to see my load temps
Let's just say that the real temperature you want to stay below is 80C.
Not 60C, since that doesn't happen unless ambient temps are very low.
Do you mind letting us know what your idle/load temps are (read by Speedfan/Asusprobe and TAT) at 3.5GHz? My E6600 using 1.5V in BIOS (1.45V AsusProbe under 100% load due to Vdroop) idles around 36C and peaks at 64C (sometimes 65-66C for a brief time) under Orthos load after a few hours, according to AsusProbe/Speedfan. TAT reports Core1/2 at 52-54C usually I believe. Never higher than 54. I'm comfortable with the temps, but Orthos seems to crash after 7-8 hours (Blend). I'm trying to figure out if I need more voltage (hopefully not) or if it's memory timings, NB overheating etc.
Thanks n7.
