I just want something that works. Right now the nvidia 3d vision solution works best - all tests I have ever read show DDD and IZ3d are significantly less reliable then 3d vision.
This is not surprising as 3d vision can be coded into the nvidia drivers unlike DDD and IZ3d who have to code around the drivers and live with any problems they cause. Nvidia also has much closer links to the gaming companies - it's TWIMTBP collaborations that are giving us fully 3D compliant games. If anything DDD, IZ3d and AMD need nvidia as they can't afford or choose not to work with devs themselves - without nvidia chances are there wouldn't be any games that work perfectly in 3d.
The 24fps over HDMI is also a show stopper, not just because it makes 3d jerky but because it also means you can't run the monitor at 120fps outside of 3d, which is currently the single best thing about owning a "3d ready" setup.
