- Aug 14, 2000
- 22,709
- 3,003
- 126
Not as good as it looks on paper: http://www.tomshardware.com/news/intel-100-series-hsio-chipset,30210.html
How is this a surprise for anyone? Its always been so on the mainstream platform and partly on the HEDT/server. Broadwell, Haswell, Ivy Bridge, Sandy bridge, Lynnfield etc.
Its exactly the same for AMD as well. Both FM series and AM series.
And now they are defending something that Intel might really.screwed up?
That's totally nuts now.... I am thinking if Kabylake is the true Skylake after all...
Remember Sandy and Ivy... They might be compatible. However, they might have different features.Come on, dark zero, can you at least try to contribute something worthwhile?
The Kaby Lake PCH is just the Z170 with USB 3.1 support. If the Skylake chipset is "really screwed up" then so is the Kaby Lake one.
The first image in that article cleared something up for me. The processor itself has its own set of 16 PCIe lanes for the graphics card(s), which can be divided up into 2x8 or 1x8 + 2x4. This discussion is only about the PCIe lanes on the chipset, which are a separate set of up to 20 lanes, plus 6 dedicated USB 3.0 lanes.
As long as FlexIO isn't eating into the graphics card bandwidth, I don't see a big problem here. I guess that the issue of a second M.2 SSD eating into available SATA ports is there; but how many super-fast M.2 drives do you really need on a consumer board anyway?
Intel's 100 Series Platforms Feature Less Connectivity Than You Might Expect
For my own part, this has killed any thought on a Z170 platform upgrade before it even launched. My next upgrade is HEDT (Skylake-E).
But if the Skylake-E chipset is just the Kaby Lake PCH, and the Kaby Lake PCH is just the Skylake PCH, with USB3.1 G2 support, then where does that leave you?
With 48 lanes on the Skylake-E CPU?![]()
This has me confused. Does this mean that if I have say a single 980 ti taking 16 lanes and a single nvme ssd taking 4 lanes then there is nothing left over bandwith wise? Does that mean any sata/ethernet/usb connection is taking away lanes from the video card?
So does having things turned on in the bios automagically steal bandwidth or does only the actual utilization of the devices. For instance, does every movement of my USB mouse slow down the 4x nvme drive a tiny bit? Does having sata enabled immediately slow things down or only using the drives attached?
