Aikouka
- Nov 27, 2001
- 30,383
- 912
- 126
I've been considering the different routes to go when building a new HTPC as well... I had to commandeer my old semi-HTPC (not really in a small case) when my server just suddenly sat on a black screen during boot up (believe it's an issue with the disk controller).
My requirements are:
- Has to fit in the entertainment centers (obviously
- Has to support blu-ray playback
- Has to support full-screen (720p or 1080p) flash playback
- Must boot up in under 20 seconds
- Must be quiet.
I looked at the newer ZOTAC ZBOX units and during the Anandtech review, he mentions that currently, there are problems with Flash in full-screen since nVidia didn't rewrite the drivers in account of the new structure of Pine Trail (too much inefficient memory access). New drivers to fix this aren't planned for a month or two, so that kind of makes that one a bust. Also, supposedly the ZOTAC can get a little loud, but it isn't as audible unless you're closer up to it. One negative aspect of these boxes is I don't think they can mount to VESA holes... which isn't a huge deal for me given I use DLPs, but some people may want to mount the unit behind the TV (ASUS's nettops can do this).
Then I looked at Mini-ITX cases. The case that I had in mind is the Thermaltake Element Q ( http://www.thermaltakeusa.com/Product.aspx?S=1321&ID=1896 ). It's a pretty nice case and I've seen it in person at the local computer store. The only problem with it is the close proximity of the PSU and the optical drive. Blu-ray drives are longer than your usual DVD-RW drives and may cause issues with connecting. I considered Atom+ION for this, but that falls under the same problem as the ZBOX. I considered a Core i3 build using the new ECS mini-ITX H55 motherboard.
Thinking that I might be better off just going a little larger, I looked into one of my favorite case companies... Lian-Li! I chose the PC-C37B ( http://www.newegg.com/Product/Produc...82E16817341016 ).
Given my requirement of quick booting, this would either require a GeexBox setup or something a tad bit more expensive. Given I don't think GeexBox supports blu-ray in any fashion, I'd have to go with something a tad bit more expensive... Windows 7 running on a SSD. Well, there goes another $250 on the price! For this, I recommend the Intel X25-V ( 40GB ). In my experiences with OCZ and Intel SSDs, I've always seen the better performance with Intel (I swear my OCZ-based system is taking longer and longer to boot!)
So yeah... the negative thing for me is my build is going to cost around $700 and that doesn't include the eventual TV tuner + extra HDD to store TV stuff on + remote.
You know what they say... go big or go home (or I guess it's go poor or go home
- Must be quiet.
