iamwiz82
- Jan 10, 2001
- 30,772
- 13
- 81
Originally posted by: 0roo0roo
Originally posted by: rh71
I've found that the recommended 30 PSI causes my Accord's tires to bulge out... people have told us we have a flat while waiting at a red. It's kinda comical...
heh, some tires have sidewalls that bulge more. doesn't mean much though. only thing that matters is that the tread is totally flat against the ground. u can sorta test this, shoe polish a stripe across tread to see if wear is even.
I use chalk, but the result is the same.
Draw a line on the tire at your current pressure and drive a little bit. Check the line. If the outer edges are more faint than the inner, your tire is under inflated, if the inner is more faint than the outer, it is over inflated. If one edge is more faint than the other, you have an alignment issue.
Also make sure you are checking the pressure of all the tires at one time, either all hot or all cold.
